I got back to this in Feb and have been working on it slowly. I started off focusing on the conning tower. On the top piece i have sanded away the molded on wood sides, added the loops where the crew can hook on their saftey harness by drilling out a small indentation and useing some fine wire. Also used some styrene for the 5 braces around the front of the tower.
The same for the other side. The 4 small white buts of styrene are the hinges for folding seats. From what i have read these were in different locations depening on the boat, on the 552 they were on the port side. There are no clear images of these seats or a clear description of them. I am guessing they are wood rather than metal or fabric, so i have cut them out from some spare pieces on the nautilus deck kit.
I have also decided to replace the kit periscope bases with some 3D printed ones. Unfortunatly they are not sold seperatly, they only comes with some snorkel parts, which i won't need, and a UZO which i already have. But i can use my other UZO for my Type IX.
The bottom of the tower has been finished, no scratching needed here, just PE and kit parts.
I will have to scratch some tubes which carry the radio wires and are at the back of this piece but not included in the kit.
The Eduard deck gun is complete, all resin and PE. Rather intricate but a nice looking piece.
And then the railing around the back of the tower. These are to thick and its recomended to make a new one out of wire or live with the thick parts. I took a 3rd option and simply sanded down the whole thing to make the railings thinner. I am happy with that.
I have since primed all this and painted the inside of the tower. I have moved on the hull to get that finished off and hopefully get both parts together soon.
And after a couple of more weeks i had the starboard side cheek piece in place. Theres a lot of work to get these fitted. Also added the torpedo doors.
The doors are actually a fraction smaller than the opening, so they need somthing to hold them in place. I use some styrene strip. Also aded the front of the torpeo tubes. These won't be seen byt they do with with strengtheing the hull.
I also added styrene inside the hull to replicate the saddle tanks. I removd ethe one i did on the port side and re-did it as it was to wide.
I then sprayed black primer on the inside where it migt be seen through the many openings.
And primed over the PE areas so i can see what more work needs to be done to blend them in.
There is still some work to do there, but i will do that after finally getting the hull together. This should make it easier to handle without damaging the rib's i added. And putting the hull together is what i did next. 3 months work, but finally got to this stage.
So thats how it looked 2 weeks ago. Been working oin the oil canning as well as tidying up around the PE parts and all the areas that needed filling. Hoipe to have another update tonight.
Revell 1/72nd Type VIIc U-Boat U-552
Re: Revell 1/72nd Type VIIc U-Boat U-552
I'm glad to see a update on this. You have put a lot of work into it and it's paying off.
Thanks Floki. It is slow going but i want to get this right.
What the said! Still looking good and moving in the right direction!
I thought submarines were supposed to be simple!
Thanks guys.
John, OOB i don't think it would be to tricky. But where is the fun in that and the kit does have some accuracy issues and i am realiseing that not al ships are the same, even those of the same class or type.
Great to see you back in the shipyard!
Have you ever seen all the valves and plumbing inside those things?jeaton01 wrote:I thought submarines were supposed to be simple!
Only in pictures and that is as close as I want to get! I heard all about submarines from a Senior Chief Petty Officer who I used to work with. At least when you die in a submarine you don't have to wait till you hit the ground to get smashed, I'll give you that.
Thanks guys.
Carlos, i have been in a more modern sub, spent 4 days on HMS Trafalgar. I can only imagine from what i have seen in books what these older boats must have been like. I would like to get over to germany at some point and visit the U-995 over there.
