Tamiya Bf 109 E-3 1/48 OOB
lawdog114
Re: Tamiya Bf 109 E-3 1/48 OOB
Post by lawdog114 »
One of my favorite kits. Pit looks great...
Joe
Von Hepp
Newbie
Post by Von Hepp »
so, after a break :sleep2: I'm back on my eagle.
I sanded the fuselage and rescribed the panellines (red arrows) but now, my references are not so good, must I add the top und bottom lines (green arrows) along the fuselage?
Armin
Armin,
She looks great. You'll get it nailed down, no worries
Von Hepp wrote:(...) but now, my references are not so good, must I add the top und bottom lines (green arrows) along the fuselage?
Hi Armin,
I let the German Wikipedia speak to answer your question. :wink:
wikipedia.de - Bf 109 wrote: Ein gutes Beispiel hierfür ist der aus zwei selbsttragenden Halbschalen aufgebaute, mit Längsprofilen versteifte Hinterrumpf, der bei geringem Gewicht eine hohe Festigkeit aufwies.
I try to translate it analogously:
The rear fuselage was a semi-monocoque construction, stiffened by longitudinal. It showed high stability combined with low weight.
Fermis
Post by Fermis »
Von Hepp wrote:so, after a break :sleep2: I'm back on my eagle.
Armin
Yes, there are panel lines along the top and bottom(green arrows).
I love this feature, as it means minimal sanding.
I make that panel line before gluing the halves together, by scraping a bevel into the mating surfaces. Just a couple light scrapes is all it takes...doesn't hurt to fit the halves together to check progress...it's easy to go too far!
I glue along the inner edge, so the glue doesn't ooze out into the panel line.
This is after only a minimal sanding to even up the halves.
I love that idea! Never would have thought of it. Thanks.
Fermis
Post by Fermis »
LyleW wrote:I love that idea! Never would have thought of it. Thanks.
It works anywhere that pieces come together on a panel line. I use it quite a bit!
That was a great idea Fermis!
Tamiya F-4B Phantom II 1/48
Kinetic F-16A (new tool) 1/48
Von Hepp
Newbie
Post by Von Hepp »
Thanks to Mostrich for the information
and a great Thank You to Fermis - this is really a great idea - now, for me, too late for this kit :sad:
But, I think sometimes the next Messerschmitt will profit with this technique.
Armin
