Kermit "does" the Yamato (1:1200) - Finished
Kermit
Re: Kermit "does" the Yamato (1:1200) - Finished
Post by Kermit »
Portman, the size and shape of the foil crumples really only makes this suitable for smaller scales but you could maybe crumple the foil up slightly less for 1/72
:shoutout: :beau: Great job on your little build of the giant battleship!
Kermit wrote:Portman, the size and shape of the foil crumples really only makes this suitable for smaller scales but you could maybe crumple the foil up slightly less for 1/72
yeah its an interesting thought - thanks Kermit
This kind of stuff just blows me away!!! Great detail and excellent work on the base!!
Kermit
Post by Kermit »
Thank you Mustang!
Now that the topic came up i did some googling on ways to create water for seascapes and found this interesting technique i am going to experiment with. It basically involves using styrofoam to create a rough swell, then covering it with Gel Medium. Appearantly artist painters use the stuff to make their paint thick and textured.
So i went to Michaels and found me a jar of the stuff and i just dumped a glob in a jar lid and sort of shaped a basic wavy pattern. Also tried to mix it up with some acrylic paint and it blends in perfectly.
As it is drying (the instructions on the jar mention it has a paint retarding effect so might take awhile...) ill try to mess with it some more and see how easy or hard it is to create a credible sea wave pattern with it
Kermit
Post by Kermit »
Have to say i like this stuff. After 6 hours it is starting to harden out but is still somewhat plyable/moldable. Definately want to try this full scale with the styrofoam layer underneath.
Also want to try an alternative: clear silicone gel or clear caulking
Nice tutorial for the base. And I like that Yamato to!
Kermit
Post by Kermit »
Purchased a 1:700 Fujimi Musashi since i completed the yamato. Should be gorgeous! Oh and while i was at it, also a 1:700 Trumpeter Warspite and 1:350 Tamyia Fletcher
Glad I found this special build and tutorial! Kermit, this is most amazing! :shoutout:
The Yamato looks fantastic, not overdone in any way. But your SBS on doing the water is superbe! Thank you for sharing this!!!
dogfish7
Senior Member
Post by dogfish7 »
Always wondered how you guys did it. Also found it very interesting to watch.
So many models.... so little time.
