1/72 Scale Hasegawa F-14 Tomcat Dual Kit Review
Re: 1/72 Scale Hasegawa F-14 Tomcat Dual Kit Review
Here is some work I did on the two Tomcats I'm doing for this review build.
It was time to add the decals to the other cockpit now. These are the decal parts that all had to be added to this cockpit. The majority of them are for the instrument panels alone:
Here are the decals added to the cockpit side panels:
These went on very well and stayed in place nicely. I did notice that these weren't cut to the shape of the side panels either, but with some simple adjustments, I got them to fit well enough.
Here are all the little decals on the instrument panels. It was a challenge getting them all on without messing up the ones placed before. The trick is to start in the center bottom and work your way up and out. These had just been hit with Solvaset so they hadn't yet sucked down into the details when this pic was taken:
Here is a shot of the two cockpits side by side so you can see the differences between the P/E set and the decals. You can see that I dry-brushed a white on the P/E parts to bring out the details:
One thing I realized later was that I had forgotten to put in a piece behind the front pilot's seat on each of these cockpits. I did try to pull the seats out but I had glued them in too tightly to remove them. Here are the cockpits next to the piece I forgot to install:
We shall see whether that will make a major difference or not once everything is put together and covered with the canopy.
Moving on, I then assembled the front gear bay and cemented it to the cockpit tubs. Afterward I installed these sub-assemblies into one side of the forward fuselage. The instructions call for 5 grams of weight to be placed inside the nose cone, but since I don't have a scale; I'm supplementing the weight inside the nose cone with the additional weight in front of the cockpit as seen here:
I then closed up the two fuselage halves on each one. You can see on the P/E cockpit that I was correct; the incorrectly cut P/E on the side consoles did make the two halves difficult to close:
With some extra pressure and clamps, I was able to close it up sufficiently and will hopefully not have a seam at all. Looking inside; it appears the P/E was not dislodged or damaged in any way. Here are both cockpits closed up inside the forward fuselage halves; the P/E one has more clamps on it:
Later on I'll add the P/E ejection seat pull handles, paint them and then close the canopy down over these to protect those P/E pieces. I will also probably mask them afterward with some liquid mask to prepare this early for paint.
That's all I have for now on this.
Those are progressing nicely. I like the dry brushed PE side consoles much better than the decals.
Not bad, those cockpits in this scale! On multi-part decals as on the IPs I usually just apply one and let it dry, before adding the next one. Takes more time to do, but there is no danger to move the previously applied one(s).
The PE parts are designed for this kit? Then one would expect they would fit, no? Good to see the powerful clamps got the fuselage halves close up!
Great work on those pit's duke!
Was that the PE that comes with the kit?
Stikpusher wrote:Those are progressing nicely. I like the dry brushed PE side consoles much better than the decals.
Thanks Carlos. In some ways I agree, although I also love the crispness of the decal details. Still, it is a great contrast to look at in order to decide which one you choose to do.
Thomas_M wrote:Not bad, those cockpits in this scale! On multi-part decals as on the IPs I usually just apply one and let it dry, before adding the next one. Takes more time to do, but there is no danger to move the previously applied one(s).
Thanks Thomas. Normally I would do something similar with the decals but I am trying to finish this quickly for the review. As for the P/E parts; I'm not so sure they were designed for this kit based on the fact that the cuts on the P/E parts did not match the cuts on the sides of the cockpit tubs. still, with some judicious positioning and strong clamps, I was able to get around that issue.
portman wrote:Great work on those pit's duke!
Thanks Stuart! Yes that is the P/E that comes in the kit. Scroll upward and you'll see my pic of the P/E fret that shows these parts. Hasegawa sure included a lot of things in this dual kit.
Thanks for that Duke - I have to say you did a good job of painting that PE up, I thought it was pre-painted.
I have to say it looks a nice kit, I have a earlier single kit boxing. Still think the lack of weapons suck but then that's Hasegawa :sad: Still a nice kit though!
I agree about the weapons Stuart. It really bites that I have to pay extra just to fit these beasties out.
Really? No missiles included with the kits? Not any?
Stikpusher wrote:Really? No missiles included with the kits? Not any?
No, not a one. They have plenty of drop tanks and some TARPS and other pods, but no weaponry. Gonna have to dig out a couple weapons sets later on...
It kinda burns me too because if one weapons set hasn't got enough weapons (i.e.bombs) then I have to spend even more to fully outfit these and any other planes. I don't always have that kind of scratch! If I had to ding these kits in any way, this would be the biggest one.
Well, this is a review build... call Hasegawa on it. In 1/48 you would have to buy one of their weapons sets to outfit one of their Tomcats with a basic load of missiles. At best you could do two if you stuck to two each of AIM-9L, AIM-7, and AIM-54. Their weapon sets cost nearly as much as the basic kit and have a lot of hardly used stuff as well. Who the hell uses Mk.81 250 lb. bombs? Or aerial target darts?
Return to “Member Reviews”
