Thanks a lot Mustang. The procedure for the water was: painting the base (just a foam) with different blues and greens and even some violett (all wall paints), then two or three coats of an acrylic crystal clear gel made by Lukas. Between the first or second clear gel coat the plane, dinghy and safty ring were placed an glued with that gel. ... if I remember rightmustang1989 wrote:I like all of these builds. I really like the He-115. What procedure did you use for the water?
This is the only pic I have of this process - this is most probably the first coat of that gel
