Thanks Joe! Fortunately, those ejector pins were easy to fix, but yeah; there were too many! As for the tracked vehicle; that has been put away so I can focus on easier models for now. The results are seen below....
Well after only three days during which I was left alone during my recuperation; I was able to get a lot of progress done on a number of models. Warning: This is a long update so please have patience with me.
Starting once again with my aircraft, I was finally satisfied enough with the white on my Boeing that I shot a coat of gloss on it:
Now I just need to find the decals for this plane and get them added.
Next I decided to paint a base green color on the Australian HAP Tigre:
Later I will mask that and shoot the second camo color on it.
Moving on, I got a lot of progress on three of my jets. Two of them are the Italian jets I've been doing. Before I show them, I'll post some comparison pictures between the Italian F-16 and the Japanese F-2A so everyone can see the slight differences overall between the two aircraft:
The Italian F-16 is on the left, the Japanese F-2A is on the right. Plan view above.
Profile view:
Upper angle view:
Okay, now that I got that done; here is my latest progress on the Italian F-16...
First I masked off the canopy which was later trimmed down when it was dry:
Once that was done, I shot the underside with Light Ghost Grey. It is tough to see in these pics, but then I am shooting grey paint over grey-molded aircraft:
I also later shot the nose with Dark Gull Grey, and when all that was dry, I masked off the bottom and the nose:
Next came the Dark Ghost Grey on the top and on the tail fin:
Again, very difficult to see. The Dark Ghost Grey is dull whereas the bare plastic is still shiny.
When that dried, I masked off the tail fin and front part of the upper fuselage:
Then came the Gunship Grey over the remaining exposed plastic:
The next morning, I removed all the masking tape. Not bad if I do say so myself:
Later on, this got a coat of gloss to prepare it for decals:
Now, since a couple of the colors were the same as the F-16; I also worked on the Italian Harrier jet alongside the Falcon. First came the canopy masking which was trimmed again after it dried:
Next came the Light Ghost Grey on the underside. I had shot it right after tyhe Falcon. You'll have to trust me on that given how difficult it is to see.....
Later came the masking, just like on the Falcon:
So, when I shot the Falcon with the Dark Ghost Grey, I also shot the topside and sides of this Harrier with the same color:
Later, when the masking tape came off the Falcon, I also removed it from this Harrier:
There you can see the two colors on this plane. Finally, I shot a coat of gloss on this in preparation for decals:
Next up, I added the canopy to the Japanese F-2A:
It fit surprisingly well. Naturally, I masked it off at the same time as I masked the Italian jets:
Finally, when it came time to start painting this aircraft, I took a bit of artistic license on this plane. The instructions call for a dark green underneath the aircraft with a Navy Blue topside. Yet, on the box top photograph of the real aircraft; the underside appears to actually be an Intermediate Blue color. It probably was a trick of the light when that pic was taken, but I like the look of the blue on blue scheme better so I shot the underside of this plane with Intermediate Blue:
Later I masked off a portion of the underside and the nose (which had already been painted a Dark Gull Grey when I painted the Falcon nose):
This wasn't masked completely because I will be coming back to the Intermediate Blue later to refine the pattern on the top of the plane. Meanwhile, I shot the Navy Blue color in an oversized pattern in the same splotch pattern indicated on the instructions:
Later on I will be going back over the top, adding the Intermediate Blue to the areas between the Navy Blue splotches with my Sotar fine-tipped airbrush. Right now this is sitting aside waiting till I have time for that.
Well, that is all I have on my aircraft; time to check out my latest armor progress.
First up, I decided to try and progress on my Russian Zil-5 truck. I added the windshield and the side windows to the cab, along with the headlights:
From the looks of things, I didn't cut that front windscreen very well. Time to pull that out and replace it.
Moving on, I was searching through my stash for one box containing the instructions for another model I was working on and I 'stumbled' over this RAF Airfield Service set that I'd already started some time ago. So, it was time to move forward on these trucks. First off I painted the interiors and assembled the cabs. First came the Bedford truck:
The top is only dry-fit on there. Next came the Tilly:
Then, since I made the Bedford into a fuel truck instead of a cargo truck; I had the cargo truck bed parts left over. Just for fun, I assembled the truck bed for the Bedford. Maybe I'll make it into a trailer or something.....
Next I started work on the German MAN truck. I decided to try something different when painting this. I 'assembled' the cab, closing it up with Silly Putty to hold it together:
I then added all the remaining bits and bobs underneath the truck bed:
Later, I added more Silly Putty to the cab and bed to cover the green that I wanted to remain green:
Next I painted the second color, a NATO Black:
While doing all that, I also masked off the German M-109 Paladin since it shares the same camo colors as the MAN truck:
Later on, when I shot the NATO Black on the truck, I also shot this gun:
After all this, I wanted to do something simple. I pulled out the Vauxhall ambulance and shot the finders and other sections with the Olive Drab ANA color:
Later I painted the rear area with the 'stone grey' they called for in the instructions. I used Dark Gull Grey, since I had it out to paint the noses of my two aircraft. Here it is dry-fit to the lower part of the ambulance:
Later on, while looking for something else to move forward on; I found my German Br-58 Panzerlok and decided it was time to paint that. I started by painting the underside and wheels. I used an Oily Black on this as a first coat:
The lights were really washing this out. I then started painting the camouflage pattern on the side. I got this far before the fatigue really set in and I fell asleep:
That pic was taken the following day.....
Okay, that completes the depiction of my marathon efforts on my hobby bench these past three or four days. I apologize for the lengthy post, but I'm thrilled to have gotten this much done.
Nice progress, Duke! I checked your AMPS forum posts last night; “stalking” you and Stikpusher if you will... really just curious to see what if any differences arise from posting in multiple forums So not stalking as much as doing field research.
I have been thinking about a vintage build in 1/72 and asked Marius for suggestions. I also wanted to have your opinion as to what vintage kits are decent. Marius suggests Heller’s Bf 109 K-4 and ESCI’s Crusader, both birds I like, so perhaps one day soon I will pounce on one!
Really, thank you for always providing such insights into building techniques with your sense of humor as well.... TGIF!
Always nice to follow Dukes prodcutions...
Love the Ambulance. As a matter of fact, anything from WW1 era is great!
Man...……...this is too much! There's so much good stuff going on here to comment on that I don't even know where to begin. All I know to say is that Mark...….you da man !!!!
Thank you for the great replies guys!
Bruce, "stalk" away my friend! Feel free to join up as well over there. That will give you another reason to join our AMPS club and attend meetings. Besides, if you want to learn about building tanks, there's no better group of guys around to give you advice. Generally, I mostly copy my in-progress thread and paste from one Forum to another, occasionally making small changes if necessary. Very easy!
Kari, thanks! I have a WWI gun to start soon too so stay tuned.
Joe, thank you! I try but none of my work comes up to the level of mastery that you put into your models. Still, I have so much fun getting a lot of progress done and finishing up a lot of models. Thanks again for the awesome compliment!
Gonna be heading out to the AMPS meeting today very soon. I'll see Carlos there again and we are gonna have some fun with all the SoCal AMPS guy! It's our tenth anniversary!
Until then, stay tuned; more to come!
So many cool projects! :yikes:
I'm curious how the 5 ton M.A.N. (Maschinenfabrik Augsburg-Nürnberg) will look like when the masking unfolds.
It's a fantastic off-road truck I loved to ride during my service in the German Army.
Thanks Mostrich! I have some more masking and one more color to paint before I can unmask the truck. Hopefully this week.
Mark, you have been one very busy bee! Aren’t you supposed to get some rest?
Nice!! :shoutout:
Mark,
Photo 23 of your post (lol, yes, I counted) depicts the underside of the a/c following a second color coat, I think primer than ghost grey, intermediate blue? That looks a lot like the Rebel Alliance grey color featured on many large ships! And if you add Luftwaffe Blue I think it could be a great Imperial T.I.E. Fighter color. Please confirm that I am understanding what happened here. Thanks!
Return to “Member's Gallery”
