Ventura Mk. II RAF Revell 1/48
Re: Ventura Mk. II RAF Revell 1/48
speedgraflex wrote:So... what is your plan with the window replacement?? I read your thread again seeking enlightenment, but I must have missed something. It looks like you have the clear kit part as well as your cast Krystal Klear (Clear?) version.
:hmm:
Going with the original part.
Spraying interior green and putting main gear together. Yawn.
For what it is worth, I went back and found the original WIP and merged it. For some reason the images from Postimage had become bad links. It sure is a PITA to go back and recreate them. So, this thread grew by 8 pages of lively, witty repartee and conversation. Back to the bench.
Thank you for editing and reassembling the thread! All the best!
LyleW wrote:Spraying interior green and putting main gear together. Yawn.
Did someone fix your Postimage links? They seem to be working now, except this one from your post on 1/11/2017
At some point in time, Postimage change its server address from *.org to *.cc. So all you have to do is modify any broken photo links and change *.org to *.cc. If I do that to the link above, I can see the photo below...
John, It was me. I just missed one.
One thing occurs with the adventures I have in modeling. I don't fear cutting into a model to fix (or try to fix) something. I also need to read the instructions more carefully. I thought I was being cute by gluing up the nacelles on this beastie. Wrong-o-reeno! I discovered pieces/parts that must be in place prior to that step. So out came the saw.
Then, I heard a part hit the floor. An advantage of laminate flooring. this isn't a tiny part....but it is long gone at this point. Traced a new one and we are back in bidness.
You blooming vandal you!
I have an idea about your window idea. Just drill a few bullet holes in the frame around it and tell people it's been shot out :lashed:
I have a brand, spankin' new Daisy Red Ryder BB gun. that should do the trick, huh?
:rofl: :rofl: :rofl:
