1:32 Hasegawa P47D "Slick Chick"
Rick
Junior Member
Re: 1:32 Hasegawa P47D "Slick Chick"
Post by Rick »
CallSignOWL wrote:great detailing!
Thanks OWL!
On The Bench
1:32 Hasegawa FW190A8 KG200
1:32 Planet Model/Hasegawa FW190C-V18/U1 conversion
1:32 AIMS/Revell Ju88 Mistel 2 Conversion
On Deck
1:32 MDC Typhoon Mk.1b
Like Bezoula Builds on Facebook
https://www.facebook.com/BezoulaBuilds
Rick
Junior Member
Post by Rick »
R2800 build complete.
Test fit, looks ok
After I weathered the R2800 I decided I need to wire it up. Carefully removed reduction crankcase housing then using micro drill and .30mm lead wire I added ignition wires.
The Hasegawa ingition wire harness is configured in an unusual way so I had to be creative to locate ignition wire holes at lower reduction crankcase housing...
and upper.
Addiitonal weathering and matt varnish to be applied later.
On The Bench
On Deck
Rick
Junior Member
Post by Rick »
BEST MICRO DRILL SET EVER!
Since I got these I have yet to use my pin vice. These are great as using your fingers you get exceptional control with superior bite and a genuine feel for the work you are doing. These are used in the aerospace and electronics industry and are made in Germany. Not the Carbide ones made in China, see eBay. I just love these and highly recommend them.
I used a .30mm bit to drill holes on the Ignition Ring and Cylinders.
Contact Allan Sidney @ allansid@alo.com Allan is based in UK. Introductory sets are about £30.00
I got this 50 bit set with a nice range of .30mm to 1.0mm sizes. This size seems to work best for me, I am all about 1/32 aircraft. However, Allan will make up a custom set for you.
They are not bullet proof as care must be taken when using the fine sizes. I did break a .30mm and .45mm. Credit to the product it was my clumsiness which caused the breakage. Steady hand is required. Noting, I was able to drill out a 1/32 scale pitot tube and underwing antenna of my Bf109 to replace with wire. Not possible with a pin vice.
Allan was great to work with. He asked good questions about my needs and was most prompt with my inquiries. The awesome storage case is in short supply. As of October, Allan had only a few available.
On The Bench
On Deck
Very nice work on the fix of the cowling. The engine looks great too!
BGB
Newbie
Post by BGB »
Hello Rick!
Superb work as always.
Cheers
Boris
Rick
Junior Member
Post by Rick »
Medicman71 wrote:Very nice work on the fix of the cowling. The engine looks great too!
Thanks!
On The Bench
On Deck
Rick
Junior Member
Post by Rick »
BGB wrote:Hello Rick!
Cheers
Boris
Thanks Boris!
On The Bench
On Deck
Rick
Junior Member
Post by Rick »
ODDS & ENDS
Lower wing root has slight gap when wings set and glued at proper dihedral.
A little plastic card nested in the gaps. Trim and scribe to come. Big gap in center fuselage is where the center tank mount will be placed.
Ejector holes on tail wheel landing gear doors filled with Mr. Surfacer 500 and sanded.
Cutting out the nav lights was truly a PITA.
Nav light cut out and will sand to fit clear lens.
Barracuda P47 Wheels Block Tread will replace the kit wheels. These wheel sets are the only game in town for any P47C or D. Rendered beautifully and weighted. Care must be taken when cleaning the spoke rims. Tires painted Vallaijo Dark Rubber and a MiG wash applied to the rims. Additional weathering will be applied later.
On The Bench
On Deck
Paul
Post by Paul »
I did the same fix to the wing / fuse gap on mine also. I found some of those yard sale signs to be about the right thickness and the right price. Those wheels look real good.
