1/48 Hasegawa A6M3 Zero (Finished )
lawdog114
- Master Member
Re: 1/48 Hasegawa A6M3 Zero (Finished )
Thanks Manny. The base is supposed to represent a portion of a simple dirt runway or field in Bougainville. It's made out of real dirt actually....nothing special.
Nothing wrong with the execution, I just find that bases rarely work with aircraft. Also, IMO, you broke a cardinal rule of having a base smaller than the subject matter...lawdog114 wrote:Thanks Manny. The base is supposed to represent a portion of a simple dirt runway or field in Bougainville. It's made out of real dirt actually....nothing special.
lawdog114
- Master Member
I didn't realize you had the rule book..at least I know where it's at should I need it for reference.
It's all good...
It's all good...
IMO = IN MY OPINIONlawdog114 wrote:I didn't realize you had the rule book..at least I know where it's at should I need it for reference.
It's all good...
lawdog114
- Master Member
Hence the "it's all good"...
Pretty slick!!!
I think the base is alright. If it were a full blown dio, then yea, the base should be bigger than the plane.
The only thing I'd do different, would be to have the plane more angled rather than "in line" with the base...but that's just me. Anyway...I like it, it looks good!
- Thomas_M
- Admin
Maybe there is such a rule in your world, Manny, but not here on this place.Manny1943 wrote:Nothing wrong with the execution, I just find that bases rarely work with aircraft. Also, IMO, you broke a cardinal rule of having a base smaller than the subject matter...
This is my world...welcome...Thomas_M wrote:Maybe there is such a rule in your world, Manny, but not here on this place.Manny1943 wrote:Nothing wrong with the execution, I just find that bases rarely work with aircraft. Also, IMO, you broke a cardinal rule of having a base smaller than the subject matter...
lawdog114
- Master Member
Think "pedestal" not so much "base". I generally do these to keep them from getting damaged, and the plane can be held by the base instead of the plane itself. The ground cover is just added for realism. Agreed, a full dio would get a larger base such as Boyington's Corsair.
