DML Dragon Hetzer Tank Destroyer Early 1:35
Re: DML Dragon Hetzer Tank Destroyer Early 1:35
Being tuned! :winkgrin:
What primer did you use?
Kermit
Post by Kermit »
Just a generic harware store laquer based spraycan. Decanted and shot through my AB
Kermit wrote:Just a generic harware store laquer based spraycan. Decanted and shot through my AB
I need to try that decanting trick...
Kermit
Post by Kermit »
Its ridiculously easy. take a paint jar or something similar you are gonna use to receive the spraypaint, tape that shut (i use tamyia tape). Then take a straw and tape that to the spraycan. Stick the other end of the straw through the tape on the jar and start spraying the quantity you need.
Let that jar sit for a few hours so the propellant gas can get out. Dont worry about that paint drying, it wont.
Good part is that the spraypaint is fully airbrushready, no thinning needed
Sounds easy enough for even me ! ;) thanks Kermit!
I never used this decanting trick. I never had to. I usually make use of Alclad´s Grey or White Primer & Filler. These come in glass bottles and are ready to be airbrushed.
Kermit
Post by Kermit »
Slightly been procrastinating after all the new years festivities (read: detoxing). But i did put down the white layer and just now added some black preshade.
Once i get some extra benchtime i will be starting on the modulated dark yellow!
Kermit
Post by Kermit »
The more i am thinking about how i am going to attack the color modulation with dunkelgelb on this hetzer, the more i come to realise a thing...
The amount of airbrushing involved with layers of shadow, base and highlight will likely remove all the preshading effects unless i can lay down the layers very thin. A good learning experience and i am eager to find out. Black basing as i currently imagine would have been much more effective.
So far I never have used this "black basing" method as seen by others. All my tanks got a got grey primer to check for flaws. After this the camo colours had been added and that´s all. Will maybe try on my next non-flying target.
Kermit
Post by Kermit »
It really does work Thomas. By simply varying the amount of paint you lay down afterwards on certain spots you create shading and chromatic variation in an otherwise dull even coat. You can probably do that over the grey primer too but the effect will be less evident and harder to achieve
