54 Chevy Sedan Delivery-COMPLETED 09/16
Re: 54 Chevy Sedan Delivery-Master Cyl & Brake Lines-07/28
Ok gang, I ended up trying to adhere the master cylinder assembly onto the firewall this morning and in the process of gluing it to the firewall I made contact between the two in the absolute wrong place on the firewall. I mean it STUCK and there wasn't any removing it without damage to the paint. I managed to break it free and wound up with a big 'ol primered spot on the firewall. Man I was pissed!!! :boom: Beyond pissed! :boom: :boom: :boom: I got up and walked away from the whole mess for about 20 minutes , came to my senses, returned to the bench and dispensed some Tamiya X-29 Black I had and shot it through the airbrush to cover up that God awful mess there on the firewall. My problem was that the vacuum hose was just a shade too long so trimmed it back and stared over again. This time I got it. If you look close you can see the outline of the boo-boo just to the right of the master cylinder but the good news is that the body L/H inner fender well will cover this up.
I also got the primer coat on the hood for the fourth time! They say the third time is the charm but I guess we'll have to make an exception here with this thing.
Today's progress:
Re: 54 Chevy Sedan Delivery-Master Cyl & Brake Lines-07/30
Great save! Looks awfully good.
Thanks Lyle. I was wondering for a minute if I was going to be able to recover from that.
Man, even when you mess up, your fixes are amazingly close to perfect! I cannot see where you had any issues. This is another way you can tell a Master modeler from simple builders like myself. Joe, you are da MAN!
dogfish7
Senior Member
Post by dogfish7 »
Even the most perfect 1:1 car will have slight imperfections, if you look hard enough. Don't beat yourself up, just fix it as best you can. Your work is outstanding! :yahoo:
So many models.... so little time.
Paul
Post by Paul »
No worries, Joe. 75 years from now nobody will be the wiser.
A great save indeed! She's starting to come together.
I really appreciate the encouragement fellas. I made some progress this morning with the rear door inside trim paneling and the door hinge in regards to painting and applying the clear coat.
As for the hood? Things continue to plague the finishing of it. I primed it the day before last, painted it yesterday and the finish came out really clean. All was well until I tried to airbrush some dispensed clear and it spider webbed on me. Looks like it's back in the brake clean for a fourth time. :headslap: Fifth try..............comin' up. I aint all that worried as I know I'll get it but man........resilient this thing is!
Man I hate when that happens! Still you have three more tries before you surpass my record of paint/strip/re-paint. You got this man.
Looking forward to seeing more.
Thanks for the vote of confidence Mark.
I got the TV glued down to the table yesterday but had some difficulty in getting the body to fit right on the chassis due to not positioning the TV in the right spot on the table. This morning I was able to remove the TV and reposition it on the table to allow the body to sit properly onto the rolling chassis. Looks like everything is fitting the way it's supposed to now.
