You have the option of painting the oxygen regulator as is or shaving off the surface detail and gluing on a circular PE piece. I elected to use the PE. So it was simply a matter of painting the regulator Tamiya Sky Blue and attaching the PE piece on top. The two gauges next the to regulator are also PE pieces so no painting on my part. The only thing I tried to add were wires coming off the oxygen regulator but they came off during the gluing process and I decided to leave them off. So the cockpit is all Eduard with a bit of careful painting.
I'm amazed at how small everything is. Feels like a 1/72 kit after working on so many 1/32 builds recently.
1/48 Eduard Bf109G-6 Double Chevron
Re: 1/48 Eduard Bf109G-6 Double Chevron
Well a 109 cockpit is pretty tight to begin with. Add to that fact that you are changing scales from 32nd to 48th... looks great no matter what scale.
kahunaminor
- Advanced Member
Ah yes, even with my sprue cutters the dreaded scab sometimes forms. I have taken to removing the sprue a bit further back then carefully sawing the part from the stub with a micro saw to limit the damage, much like one does with a clear part.jkim wrote: There are some gouges where my Tamiya cutters pulled out small sections of plastic when attempting to remove the remnants of the sprue attachments. Minor but I keep conjuring up images of Bruce's Gods Hands cutters in my mind. These gouges and other seam imperfections have been filled with Mr Dissolved Putty.
Regards,
Kent in Oz
John, you’re kicking wholesale ass on this build and I’m loving watching it come together.
kahunaminor wrote:Ah yes, even with my sprue cutters the dreaded scab sometimes forms. I have taken to removing the sprue a bit further back then carefully sawing the part from the stub with a micro saw to limit the damage, much like one does with a clear part.jkim wrote: There are some gouges where my Tamiya cutters pulled out small sections of plastic when attempting to remove the remnants of the sprue attachments. Minor but I keep conjuring up images of Bruce's Gods Hands cutters in my mind. These gouges and other seam imperfections have been filled with Mr Dissolved Putty.
Regards,
I am gonna order these for you, John!
That's what I need: a pair God's Hands! LOL... I love that name!
I also cut my pieces away from the sprue connection. But instead of sawing, I use the cutters parallel to the joint, which USUALLY results in a clean cut close to the surface. Since the Tamiya cutters are so handy, I've made the mistake of cutting other things with it like wires and even the nubs off of PE pieces, which I think has compromised the cutting edge a bit. I still prefer the Tamiya cutters over the still new Xurons that I picked up some time ago.
I am currently cleaning up the fuselage seams the G-6 with Mr Surfacer 1000. Once that is done, I'm going to do some scribing and riveting to restore the lost detail.
kahunaminor
- Advanced Member
Ah yes, I am the same with my Xurons. I have also used them for other tasks and have probably damaged the cutting edge. I am on my second set, having decimated another set doing the same thing. I now try and keep them exclusively for sprue trimming but as you say they are close and handy at all times!jkim wrote:That's what I need: a pair God's Hands! LOL... I love that name!
Regards,
Kent in Oz
You reminded me that one of the things I remember in my Dad’s small tools kit was a pair of Xuron cutters. I have no idea what happened to them! I also miss his collection of drill bits. I did find a scribing tool he used to use. I was gonna practice with it while waiting for the scribers to appear.
I have a basic cutter from Mr Hobby which I use for everything but sprues. So far I have not screwed up the edge... but it is early days yet.
Fiddled around with the G-6 for past few days and have accumulated enough photos to report on it. Hartmann's G-6 has the later tall tail so I've added the appropriate top half of the tail fin. I like how Eduard added detail to the inside surface of the tail fin cut-out in case you want to pose the rudder off neutral.
Every 109 kit that I've ever seen has trouble molding this hatch. Eduard supplies a PE plate to address this shortcoming but I thought I'd scribe a new one.
I filled the existing hatch with CA glue. I only have square hatch templates so I had place the scriber twice to get the appropriate rectangular shape. I use a sewing needle chucked into a pin-vise for scribing hatches.
Here's what the finished hatch looks like after clean-up and a shot of primer. I'm also in the process of cleaning up the fuselage joint and restoring rivets.
I haven't glued the gun cowling on yet. I want to place the gun barrels carefully, so I did it when the cowling is still unattached. I don't want the gun barrels laying on the gun trough but clear of all of the gun trough surfaces. This looks better and will make painting easier.
A quick check to see how the canopy pieces fit after the rear pilot bulkhead is put into place. The Revell instructions do not call for this part but some sources have noted that this machine had the square battery box enclosure. Oops... it looks like one of the seat harnesses has gone missing!
Some of the cleanup work on the fuselage seam. I'm using the RB Rivet-R tool in 0.75mm even though this does not quite match the Eduard rivet spacing.
On to the landing gear... Eduard provides one-piece tiress but separate hubs. I thought I'd take advantage of this and paint the tires and hubs separately. Late 109 wheels can be tricky to paint in that the wheel hubs were commonly black. I like to manufacturer some contrast between the tires and hubs.
I've decided to take a page from my 1/32 bag of tricks and use small sections of brass tubing to help connect the brake lines (which are lead wire) to the landing gear legs.
The landing gear legs were painted Tamiya RLM Grey, which is fairly close to RLM02. I use slightly lightened Grey to highlight some sections of the legs just to increase visual interest. The legs were then given a gloss coat, a dark pastel wash and then a flat coat. The end of the brake line was terminated in the characteristic loop and then painted black.
The tires were painted in a custom mix of Dark Grey, Brown and Black and the wheels were painted black with some grey accents. I wanted to do something different with the tire treads. The easiest is to give the recessed treads a pastel wash that is lighter than the tire itself, like light brown. It highlights the treads but unless your aircraft is in mud, I don't feel that this is a very convincing treatment. I think the recessed tread should be darker than the rubber that is in contact with ground, for most dry situations. After painting the tires that dark grey/brown, I gave the outer rim of the tire a spray of a lighter brown, to help provide contrast for the next step. After sealing the paint with gloss, I gave the treads a black wash. Further wear was imparted to the tires after the flat coat with dry pastels.
Time to paint the exhaust pipes! This is actually a very quick step and doesn't really require any cure time between coats. But it illustrates a multi-layered approach to painting a simple object. Instead of painting the exhaust pipe a rusty brown and calling it good, I like to try and give the exhausts a bit more definition and interest.
I start with my normal step of giving the exhaust a coat of black primer.
Alclad Stainless Steel is applied over the black. This step can probably be skipped at this scale since it is very hard to distinguish it at the end.
Alclad Exhaust Manifold gives the pipes a bronze-ish tint.
Next, I load some black into the airbrush. First, I shoot the exhaust pipes directly from the back, into the exhaust openings . If you spray straight, the black should not affect the rest of the exhaust pipes, just the open ends which you want to be black to give the appearance of being hollow. Then, I will highlight the tips from the top with black . I use a Post-It to isolate each exhaust tip. This helps to give the impression of a something hot and dirty exiting from the end of each exhaust and also serves to separate the exhaust pipes from one another.
Hard to see the effects of the black treatment, especially at this small scale.
For the next step, I mix-up a little batch of rust color (brown, red and orange). Using a small stiff brush, I dapple the rust color onto the exhausts. Similar to dry brushing but using a poking motion with the brush.
Highlighting the tips of each exhaust with black is repeated for the final step.
Here's the finished exhaust mounted in the fuselage. Notice that you can see the bronze color in front of the first exhaust. For exhaust pipes that are molded this way, it is a good idea to black out the base prior to installation. Both exhausts will be somewhat obscured by exhaust deflectors so I'll double check this before it's glued into place.
