TJ's Accurate Miniatures F-6A/ Mk.Ia double build
Re: TJ's Accurate Miniatures F-6A/ Mk.Ia double build
The camo colors look great TJ. Those Accurate Miniatures Allison Mustangs build up real nice!
- tempestjohnny
I saw that in the pic. I'll have to look at the model I never noticed itjeaton01 wrote:The paint looks great, John. I don't think there should be a visible join on that carb air intake on top, though.
- tempestjohnny
I believe I've fixed the issue. Thanks for pointing that out John
That's a good effort on that paint Johnny. Spraying that second color can always be tricky when going for the ultra thin layers of paint but it looks like you pulled it off well.
- tempestjohnny
- tempestjohnny
I found out that middlestone was field applied right over the ODmustang1989 wrote:That's a good effort on that paint Johnny. Spraying that second color can always be tricky when going for the ultra thin layers of paint but it looks like you pulled it off well.
- jeaton01
They look great.
Great progress. I've never done two of the same kits at the same time - probably saves time I imagine.
- tempestjohnny
I've done it a few times. In 48th scale two is not that bad. 72nd I did 5 Airfix Mustangs all at once with 2 Academy ones thrown in.keavdog wrote:Great progress. I've never done two of the same kits at the same time - probably saves time I imagine.
