The restoration looks accurate to the original design of the brackets!
From memory and the photo it was Perfect Plastic Putty from Ultimate Products. It is a water based, acrylic putty that is very malleable but sets hard and can be sanded, but dry sanded only for if you wet sand it sends the putty back to its more liquid form. It may even be Vallejo acrylic putty as that is a similar product. I use PPP on my builds and really like it. You can use it directly from the tube, a little at a time ad work it into the seam. A wet finger can be used to remove excess, minimising clean up. I have also started using it with added water to get a more liquid consistency. I will add some photos when I set about my G-5 cockpit fix later in the week.speedgraflex wrote:Yes, that fella was not messin’ around. That is some filling badassery and then some. Filling those gaps with sections of card is mighty cool. I do not remember if he wrote what he used as filler—looks a bit like Tamiya White, perhaps?Stikpusher wrote:Now that is some excellent work on filling those gaps!
Nice job priming, too.
