Warning about the SAC gear. I've ready pretty crappy reviews... no added detail as they are molded directly from the kit parts... soft metal that is easily bendable. Never used SAC myself so that's just secondhand info. On the other hand, I've had positive experiences with the metal legs from G-Factor and Eduard.
There are different ways that you could add brass tubing for the exhausts. I'm thinking that it would be difficult to cut the existing exhaust stubs and the new brass tubing at precise enough angles. It might be easier to cut off the existing pipes completely and drill holes all the way through the base part so that you'd have some wriggle room for adjustments (length AND angle).
Sorry for mucking up your beautiful hand drawing with the crappy Powerpoint graphics.
