1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
Paul
Re: 1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
Post by Paul »
This is over the top
pg265
Senior Member
Post by pg265 »
Good evening,
Firstly a big thank you to you to follow the WIP of the small marvel from TAMIYA :wub: .
And of course a big thank you for all your kind comments! :oops:
Wheel wells are superbly handled by Tamiya and their installation is precise and cleverly designed : a joy to build!
I find that some details can still be added very simply. It will give a little more reality to this space that is a bit empty.
The hydraulic distributor is prepared, lightly modified, drilled and finally equipped with its piping.
It was finally set up against the front wall of the bay.
Other pipes depart from the distributor through the aperture provided for this purpose.
Others from the wall, walk behind the retraction actuator to reach the small forward compartment.
Various pipes installed on the root partition side are formatted to run on the bottom of the compartment and back on the opposite to finally get lost in the passage toward to the folding part of the wing.
Well, after all this :blah: as preamble, pictures.
They are taken with and without flash in order (achieved or not? ..) More clearly show the details.
That's all.
Not much for today, but it's pretty long and time consuming.
More soon,
Pascal :stirpot:
pg265, I can hardly see this with the magnification! I'm amazed at your level of detailing. Beautifully done, sir. :bow:
pg265
Senior Member
Post by pg265 »
Hi,
Thanks a lot LyleW ;)
Little progress in appearance, but it's an important step that is preparing to be crossed.
Wheel wells are now detailed and will allow me to soon spary the interior color on that part of the plane.
Oil coolers assemblies are also ready to be painted "Salmon" then "Light Gray".
La baie de droite:
The hydraulic distributor of the compartment:
Installed:
I lost one and ...still does not explain to me the relentless calm that I showed face the ordeal.
This one comes from one of the other boxes; but I'll have to order a sprue to replace the part...
One of the wings oil coolers:
I replaced the original photo-etched by the one proposed by Radu Brinzan, and masked it before primer and camouflage.
The parts are much finer and detailed than the kit ... already pretty!
Everything is connected:
One of the wing root extrados:
Voilà, voilà.
More soon.
Pascal :Shark:
This is just brilliant! :bow:
Fermis
Post by Fermis »
DAMN!!!
I'ts been too long since I've checked in on this one....too much to take in all at once.
VanceCrozier
Post by VanceCrozier »
Gorgeous! :bow:
pg265
Senior Member
Post by pg265 »
Hi,
Thanks a lot Mates ;)
To continue on the wing and the central portion particularly, I started to work on the flaps.
These "Belles Bêtes" so special and identifiable amongst all!
The Tamiya assembly is of impressive quality and rendering without external addition is already terrific.
However, I decided to replace some kit parts by few photo-etched from Eduard.
This also causes a bit of rework on some kit parts ... that will need some adaptation .
The result, however pleases me, so it's worth a little extra work.
First, inside flap:
Central flap:
You have to think to open the perforations of the original parts to give a little more meaning to these details.
Outer wing flap:
Tamiya PE parts to detail the internal sides of the flaps:
Wheel well doors: STUNNING
You just have to slide the doors on the installed actuators to finalize this step!
Perfect angle for both right and left doors:
Voilà.
Pascal :shoot:
:dogwag: So cool!
:yikes: PG, sir, I have to go buy a Thesauras. Be back later. Wow.
