Bolleken's 1:72 stuff
Re: Bolleken's 1:72 stuff
I would try mixing grey acrylics with Future to create a soft light wash to tone down the wing root chipping. Photos I have seen of Corsairs in action in the Pacific reveal a heavy contrast coat of darker engine oil pattern on upper lower forward wing surfaces. A symphony of heavy tropical weathering effects!
Bolleken
Post by Bolleken »
speedgraflex wrote: I would try mixing grey acrylics with Future to create a soft light wash to tone down the wing root chipping. Photos I have seen of Corsairs in action in the Pacific reveal a heavy contrast coat of darker engine oil pattern on upper lower forward wing surfaces. A symphony of heavy tropical weathering effects!
Bruce, great photos. I always wonder where you get those?
Phantastic and many thanks, Herr Kollege!
The top one looks to be computer colorized, but the lower photo looks to be original color.
Thanks, Marius. I like collecting photos and your choices inspire me to go look for more. The P-47 came about partly because I started looking at P-51s on your 2017 list. Carlos is right - I almost pulled down the first photo as it is colorized. I liked the way the salt moisture aircraft engine oil and brilliant sunlight were transforming the blue into a kaleidoscope of greys. The above is color original. Were Navy photographers using Kodak? That looks like a scan of a Kodak slide film stock to me.
Bolleken
Post by Bolleken »
When I look at that last one my chipping is not that far away...
The chipping is great. Based on what I see in your photos, I think the blue needs to be sun faded a bit, and I suggested washes with acrylics - slightly more delicate but easier to reduce if these become too potent. I also think the washes should be heaviest where the sun is strongest, but that may be incorrect; you might need to add a pinch or two of yellow to the grey on top to warm things up.
Nice to see the salt chipping technique. I use it more for fading effects rather than paint chipping but It seems to have worked ok for you. The only thing I can say is... be careful about the salt residue! It has an annoying habit of showing up as white cloudiness after applying a flat coat.
Impressive work Marius! I also like both aircraft.
Yes Bruce, the navy photographers were using Kodak film. I believe Kodak had a contract with the armed forces to supply them the film they needed to capture everything on film.
Keep going; this is looking great! And thanks Bruce for the great pics. I love checking it to see what you might end up posting next!
Bolleken
Post by Bolleken »
It has been finished!
Wanna see more?
Good gravy! Yes! Do you even have to ask! Echo some more photos, please!
