Monogram B-17G Out of Mothballs
TheMongoose
Re: Monogram B-17G Out of Mothballs
Post by TheMongoose »
“Latest update. Installed Radio Compartment Gun n Glass. Trying this Vallejo plastic putty. Not thrilled with it. More like Caulking than putty. I would never use it on a NMF. “
Plastic putties are great for thinner seams. When the gap is a little wider i use clear coat over it to seal it before painting. For nmf you seal it with thin superglue and it’s invisible. People love it because it doesn’t require sanding. Always great when you want to avoid sanding away a bunch of hard to recreate rivets and panel lines.
Myself i use the Perfect Plastic Putty. I think like everything else in this hobby it has specific uses, not an all purpose do everything solution.
Love your caulking comparison! A buddy and i were talking a couple months ago and he said he uses drywall putty as that’s really all these are :giggles:
I saw the stuff at my LHS two weeks ago and figured I would try it... Should have known better after 30+ years of building. I've only ever used super glue and epoxy putty for filler in that time. I guess there was a reason for that :hmm: I am sure it has it's uses, just not for filling gaps. Probably makes some nice zimmerit, seat cusion, etc...
TheMongoose wrote: Sat Jan 28, 2023 11:13 pm Myself i use the Perfect Plastic Putty. I think like everything else in this hobby it has specific uses, not an all purpose do everything solution.
Nice, neat work sir! Your seams look clean even in the close-up photos. Try Black CA glue +Insta Set for those small gaps. You can work on it instantly instead of waiting 12 hours
Thanks for the tip, but the reason I have to wait 12 hours is because this CA is like 12 or 18 month old, so it sets up very slow. If I added nail powder to new CA, the working time would be almost nothing. This also works very good if you want the CA to have a long time to level out before setting.
Monkey = Off Back
Man the windscreen is a pain on this kit. Finally got it installed and painted! Filled the gaps with extra thick CA, immediately wiping smooth with cotton swab. Naturally, I had to future the thing first to prevent fogging.
Glad I bought these Eduard masks. Great Time Saver. And based on how long I've been working on this kit, they only cost me about .50 cents a year... The overhead glass masks did not fit that great though. Well the port side fit well, but not the starboard. I think Eduard made the mistake of thinking one side would just be an exact mirror of the other...forgetting how kits were designed in 1975 :giggles:
Nice paintwork, Chris.
jeaton01 wrote: Sat Nov 11, 2023 3:14 pm Nice paintwork, Chris.
Indeed! You’re really making those raised panel lines look like the overlapping skin panels of the real B-17.
Perfect analogy
Thank you kindly John, Carlos and John !
tempestjohnny wrote: Sun Nov 12, 2023 8:26 am
Stikpusher wrote: Sat Nov 11, 2023 3:22 pm
Perfect analogy
Brandons_Iron
Post by Brandons_Iron »
Continuing to look extraordinary in workmanship and details. I've always been impressed with your work on this one and more, but especially this one. :shoutout:
BrandonK
