Revell Spitfire Mk IX 1/32
Re: Revell Spitfire Mk IX 1/32
speedgraflex wrote:No worries, Kari. Not embarrassing at all. Usually the first posting is either photo- or text- heavy, so that makes editing trickier.
Tx, that's true of course!
Hey!
I was thinking about your wing root gap situation last night because I have a similar issue with the Hasegawa wingspan. The lower piece is definitely flatter than it should be. Last night I took out my travel steamer for clothes and gently heated up the plastic to see if I could get some action. The results seem promising; I was able to add back at least a small amount of flexibility. I don’t know if I can quite close the gap but I would like to keep trying the steamer out to see if this will adjust the dihedral.
I am thinking I might spring for Pacific Coast Models 1/32 Spitfire Mk. IX Type No. 361 which was released in 2008. I believe it still is in production. 70 parts grey plastic. 9 parts clear. 21 resin. Color PE fret. Markings for 6 aircraft.
http://www.hyperscale.com/2008/reviews/ ... ewbg_1.htm
speedgraflex wrote:I am thinking I might spring for Pacific Coast Models 1/32 Spitfire Mk. IX Type No. 361 which was released in 2008. I believe it still is in production. 70 parts grey plastic. 9 parts clear. 21 resin. Color PE fret. Markings for 6 aircraft.
Ooooooooooh, that looks really really good!
Do it !
A very interesting thread Kari - that cockpit looks fantastic. I'll be interested to see what the wingroot gap is once you've fitted said cockpit into the fuselage halves.
:popcorn:
Cheers!
portman wrote:A very interesting thread Kari - that cockpit looks fantastic. I'll be interested to see what the wingroot gap is once you've fitted said cockpit into the fuselage halves.
:popcorn:
Cheers!
Thanks Stuart ! :-)
I need to (have we heard it before?) continue with this build... "just" to add the seatbelts and then the project can continue... So easy but so difficult... :blush:
Thanks Stuart ! :-)
- Kari[/quote]
That's always the way!
BTW - IIRC the crowbar/hammer thing fitted to the doors were black - not red! That's a postwar restoration thing. That being said - from an artistic veiwpoint the red does look nice.
Cheers!
portman wrote: BTW - IIRC the crowbar/hammer thing fitted to the doors were black - not red! That's a postwar restoration thing. That being said - from an artistic veiwpoint the red does look nice.
Cheers!
Thanks Stuart confirming this! Indeed, red would be more "dramatical" but so wrong!
Black it will be
Cheers!
Black it will be
No worries!
You should throw the Tamiya IXc into the mix too... state of the art Tamiya molding plus a full engine that's displayable via magnetically attached cowling.
http://www.hyperscale.com/2009/reviews/ ... ewbg_1.htm
You can get it shipped from Japan for about $97, which probably isn't that much more than the Pacific Coast kit.
