1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
BsYamato
Re: 1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
Post by BsYamato »
Feels like this is a good bibble about how to build an R-2800 and a corsair :yikes:
wasabi
Post by wasabi »
The weathering looks amazing, especially on the blue parts. Your build is a pleasure to follow: concise text and clear explanations !
Antoine (toniosky on master194)
pg265
Senior Member
Post by pg265 »
HI,
Thanks a lot for the kind words Mates!
Merci Antoine! Heureux de te retrouver ici ;)
ZP is Zero Paint Thomas.
Mainly used for cars and bikes kits.
You can find the complete range at Hiroboy.
Small update.
I cut the front exhaust plate.
Kabuki Stars for the next step
Insigna Blue... and problem with the Gunze white
sanding with 6000
Micro Flat.
... Insigna Blue
Maskol on the ZC this time
I made my own mask.
More soon.
Forza Jules.
Pascal
pg265
Senior Member
Post by pg265 »
Hi,
Paint job update.
Kabuki "Stars" out and light 8000 sanding on the full disc
Before a full disc mask
Blue Grey (Aeromaster acrylic)
Liquid mask before sprayed semi gloss black
Frisket mask for the side Stars
White (RLM 21 Aeromaster) spryed over the mask
Maketar star
Aeromaster Insigna blue without mask to avoid paint thickness
Quick 8000 sanding and the center of the Frisket mask is installed over the disk
Tamiya tape out again
Grey ZP primer
Then Semi Mat Alu from Alclad
First chipping step with Maskol
Zinc Chromate (Model Master Acryl)
And Maskol again
Aeromaster Blue Grey is finally applied on the plane
That's all.
Pascal :Shark:
Simply WOW! :)
Stunning. This should be in a book!
pg265
Senior Member
Post by pg265 »
Hi,
Thank you very much Mates.
Started to work on the Blue Grey.
First step with lightened Blue sprayed with 0.2 nozzle.
Light color is a mix of Blue Grey and Light Gull Grey from Aeromaster.
Surface is rubbed with a soft cloth for a smooth paint surface and to remove the Maskol
Then oils
Raw Umber W&N on the panel lines.
Then Sépia (Rembrandt), Titanium White, blue... between fuselage frames , worked with lighter fluid.
Same on stars
White tape will soon be put over the gun muzzles
I've also tried to represent the discoloration due to Avgas leaks on the fuselage sides
And few leaks and fluid traces
Paint of the canopy is done
Overviews of the progress
Voilà.
Pascal :stirpot:
This paintwork deserves a standing applause. Good grief!! Is there any way you can go into more detail about how you got the paint chipping/ wear? I have GOT to use this technique. :wow:
This really should be published. Somewhere, somehow. We can get it self-published through some of the online services....This is the how-to of how-tos.
