Page 1 of 6
Me 109 E-7 Eduard 1/48
Posted: Thu Feb 12, 2015 1:02 pm
by ajcmac
After finishing the P-40 another model on the bench. Started a long time ago and because I had other models with more interest returned to the box. Let's see if this is I can get to the end.
The chosen version.
What had been done.
Regards
ajcmac
Re: Me 109 E-7 Eduard 1/48
Posted: Thu Feb 12, 2015 3:09 pm
by ShadowRyder
That is one of my favorite schemes on the E. Love what you have done so far, I'll be tagging along for sure!
Posted: Thu Feb 12, 2015 6:09 pm
by CallSignOWL
love that desert scheme!
Posted: Fri Feb 13, 2015 5:03 am
by BorgR3mc0
ShadowRyder wrote:That is one of my favorite schemes on the E. Love what you have done so far, I'll be tagging along for sure!
yes, that is a great scheme!
Posted: Fri Feb 13, 2015 8:03 am
by Thomas_M
This scheme will look very different later on a model show desk!
I always wonder how you guys get some wire lines laid down this exactly on your cockpit side wall builds... :sad:
Posted: Fri Feb 13, 2015 9:06 am
by CallSignOWL
Thomas_M wrote:This scheme will look very different later on a model show desk!
ya dip the wire in a bit of superglue and then put it where ya want it
:blah:
Posted: Sat Feb 14, 2015 6:58 am
by Thomas_M
:blah:
Doing it this way it forever stays put on my fingers... :whiteflag:
Posted: Sun Feb 15, 2015 11:55 am
by Fermis
Thomas_M wrote:
CallSignOWL wrote: ya dip the wire in a bit of superglue and then put it where ya want it
:blah:
For what it's worth...I work from point to point.
If and whenever possible, I drill a tiny hole at the start point. Dip the end of the wire in a drop of CA and cram it in the hole...let sit for a minute...make any bends (if need be) between the start point and next point. I use a thin piece of stretched sprue as an applicator, to place a tiny dab of CA at the next point, hold wire on that point...let set...and repeat till the end.
On the fuse half at top of pic, you can see that I further reinforced these "points" by adding a "bracket", cut from foil. A tiny dab of CA above, on, and under the wire/wires...place the foil strip on the wire...use tweezers to press the top and bottom of "bracket" down (at the same time).
Posted: Mon Feb 16, 2015 1:22 pm
by Thomas_M
Thanks a lot, Fermis! Looks this easy when you do it...
