Page 5 of 7
Re: Sharkmouth Bf-110c
Posted: Fri Apr 17, 2015 8:45 pm
by Manny1943
CallSignOWL wrote:BlackSheep214 wrote:Steel wool? How do you mean you'll buff things up with steel wool? Curious and eager to learn a new trick or two....
yah, I take a glob of 0000 steel wool (find it in the paint section at at hardware store), and scrub the plane with it. The 0000 is a finishing grit, and it evens out the paint ridges, as well as making things smooth for the gloss coat. Kinda gives things a semi-gloss sheen. You can also use it on BMF to change the tone of the foil
this is the bag I have, I think it was only like 4 bucks or something. Its lasted a long time too!!
I've used the stuff for years on all types of models: armor, figs and a/c...just remember to use the very fine grade of it...it will actually
polish
the plastic...works well on most resin too...
Posted: Sat Apr 18, 2015 4:02 am
by mostrich
Great tip, thank you!
Posted: Sat Apr 18, 2015 5:42 am
by Manny1943
mostrich wrote:Great tip, thank you!
No problem. The best thing about it is you can tear small pieces from the larger pads and ball it up like a sponge to attack difficult areas like wing joints and other compound curves and it does a faster job and covers more area than sandpaper because everything it touches is getting smoothed out...just make sure you but the kind without the embedded soap in them...and the finer grits like 000...just sayin...
Posted: Sun May 03, 2015 6:29 am
by CallSignOWL
so, got into a bit of a funk there, but Im trying to work through it.
gloss coat has been applied, and Im starting on decals!
Posted: Tue May 05, 2015 3:09 am
by Stuart
Looking Goood thoug - as is the Beau!
Posted: Tue May 05, 2015 6:56 am
by LyleW
well on the way! looking good.
Posted: Tue Jun 09, 2015 7:54 am
by CallSignOWL
Working through my funk took a while but I've actually gotten this one finished! Final pics should be up in a day or two.
Posted: Wed Jun 10, 2015 4:26 am
by Stuart
Posted: Wed Jun 10, 2015 5:38 am
by CallSignOWL
portman wrote:
I know right?!?!
Posted: Wed Jun 10, 2015 6:05 am
by Stuart
No worse than me - I've done a bit of work on the A-7 but havn't taken any pic's yet....
