1/32 Eduard Me109E3
Posted: Tue Sep 22, 2015 4:55 am
Well, I finally finished this. For those of us that worry when we lose our mojo, let this be proof that it does come back. After a good 3 months of not really feeling like building anything, my motivation came back 10 fold! In the last month or two, I have built (and finished even), the last crewman for my halftrack, (see Tamiya M21 under the armor threads), 3 1/48 aircraft for my grandsons, (F-16,P-39, P-51), and now this 109. I've also recently started a 1/32 MiG-3, and haven't decided if I'll start my Hs129 or PBR next. Maybe I'll start both...
Anyway, here she is, done up as Josef Priller's ride.
I haven't built a base for it yet, so I put it on one I had made previously for a 1/48 Me109 that I gave to a friend. I may just leave it.
There are a couple things I'd change, if I was to do this one over. Primarily paint. Model Master RLM02 seems to look too much like concrete to me. I'd use a grey with bit more white/blue to it. I'd also find a better contrast to my mottle. Not much, but just enough to distinguish the different shades a bit more. Possibly even bring my blue up the fuselage sides a little higher. Also, I'd pay a bit more attention to my pics, and angle the antenna wire entering the fuselage, like it's supposed to be.
Otherwise, the kit went together exceptionally well. A little finicky where the lower wing attaches to the body, and the center seam on top was a bit pronounced, but nothing some good putty, sanding and a bit of time didn't fix.
The weakest part of the whole model, was the landing gear, (art imitates life), as the struts were thin, but the mounting points were really the issue. Not deep enough to give a good, positive, strong lock. I know this because shortly after installing them, I first broke one, then the other, just by bumping them with my arm. I would suggest, at a minimum, that you drill out the center and add a short piece of brass rod to reinforce them.
Other than a few other minor fit issues, I found this to be a well engineered and fun kit.
Thanks for looking
Thanks for looking
