1/48 Revell F-106
Posted: Wed Jun 01, 2016 4:40 am
Although my spring & early summer have been crazy, I haven't been completely idle at the bench. A friend gave me a 1/48 Revell F-106 to help thin his stash. Even though I rarely build in 1/48, I use them as a test bed. In this case, I covered it in Bare Metal Foil in order to see how well it would work should I decide to cover my 1/32 B-17 with it. For those who may not know, Bare metal Foil is an extremely thin sheet of self adhesive foil. You can apply it to any surface. I burnished mine with cotton swabs and a very dull, rounded balsa stick to get sharp edges. The best trick I can suggest, is to cut out a piece slightly larger than you need, then trim it along the panel or seam lines. This allows the adjoining sheet to align with little to no seam visible. As these pictures will show, it worked fairly well, however it was extremely labor intensive and certainly not what I will use to cover such a large aircraft. Since the question was foil or Alclad, I will be using Alclad.
And so it begins....
Had to trace and cut out where the intakes will go. Cement won't adhere to it very well.
The panels and doors are starting to become more visible
Certain areas were painted first in steel, such as the refuel port.
Decals were applied as normal using Walthers solvaset. Only exception, was that there was no need to apply a gloss, or Future, undercoat since the foil is already smooth. Once I upload some of my other pictures, you'll actually be able to see the markings reflected on the wing. Pretty amazing.
On a side note, this particular aircraft took 4 sheets of Dull Aluminum BMF, which would barely be enough to cover just one wing of my B-17, not including engine nacelles! I may use it on the interior though. Also, when using it, try not to apply each sheet in the same direction. It does have a super fine grain to it, and by mixing it up, you can get the variations in shading I have here.
Until next time, thanks for looking!
