Page 1 of 3
Ki-51 Sonia Hasegawa 1/72
Posted: Fri Apr 25, 2014 7:34 am
by BsYamato
Another jap on the table, recent acquisition from private vendor (same that gime me other four japs and two other rare kits)
The Sonia was a light dive bomber and reconnaissance plane, i'll build it as second type
Just sprues, this one was part of a combo box
As you can see the wheels are moulded wit a part of gears, will try to ennanche this feature, also thinning the cowling thickness
the result
cut out too many flaps.. the correct is only the central piece as i see after consulting references :roll: the two on sides alrerady re-gued in place in the picture
exhausts holed
fuselage detailing after sanded the few original ones
the cockpit floor is already detaild but..
new pilot seat scratchin
adding more realistic details to the floor and the stratched flap before sanding to correct shape
rear seat ready and pilot seat too, just left a pillow for the pilot :)
the flap sanded
added more pieces to the floor and test with seats
that's all for now :)
Re: Ki-51 sonia hasegawa 1/72
Posted: Fri Apr 25, 2014 8:21 am
by LyleW
Looking good Mr. Y...looking good. Do you ever sleep?
Posted: Fri Apr 25, 2014 8:37 am
by VanceCrozier
Looking beautiful as usual Bsyamato! I can't say I'm all that familiar with this machine - looking forward to the build.
Posted: Fri Apr 25, 2014 9:42 am
by BsYamato
LyleW wrote:Looking good Mr. Y...looking good. Do you ever sleep?
LOL about 6 or 7 hours par night :) i forget to speak that this kit was started about two weeks ago :lol:
here a test fitting Vance
this is the original mania box
Re: Ki-51 Sonia Hasegawa 1/72
Posted: Mon Apr 28, 2014 7:49 am
by Medicman71
Looking great BsYamato!
Posted: Mon May 05, 2014 9:04 am
by BsYamato
Thanx Medic :)
here more:
Radio apparatus and engine commands
glued and added other details to the left cockpit wall
Worked on the flap housing too, the structures must be sanded at the same height
At the next
Posted: Mon May 05, 2014 9:13 am
by LyleW
Astounding scratch work. Looks good as does the entire piece of work.
Posted: Tue May 06, 2014 7:37 am
by Medicman71
Man I love watching your builds. Always great to see the scratch building that you do.
Posted: Tue May 13, 2014 10:41 am
by BsYamato
Thanx for comments guys :)
Not much time to post, here lots of updates
sanded down the flap housing structures
Added more details to the cockpit walls
And the floor, ready for paint session
scratchin the used ammo can pockets with aluminium foil
the home-made mix for the interior green
and paint everywhere after vallejo primer
painting details
engine ready
Pilot seat , IP and radio ready
Floor almost complete
walls too
Also worked on rear gun and belt. used masking tape, copper wire , plastic scraps and stretched sprues
ready for paint
And finished, as for other pieces used italeri acrilics and chainmail color from citadel
Few things done last days but not yet pictures , at the next :)
Posted: Wed May 21, 2014 11:28 am
by BsYamato
Some update that forget to post :!:
working on the reconnaissance camera
and painted, used revell vinyl glue to simulate the lens, not yet dry in the pictures below
Added platic tubes in the inner of exhausts to improve the dept effect
glued pieces to the fuselages before to close
Some problem with the camera and the radio spacing... some adjust was needed :geek:
the mummy
detailed the inner under floor parts before to glue wing
warned by a friend that is building the same kit i put a spacer under the engine base to avoid propeller/cowling contact !! also some filling in the propeller gaps
wings on, some problem to fix it caused by flap modify
actually glued all main pieces but no time to upload the pictures :(
At the next!
