Page 1 of 5
1/32 Trumpy AV-8B Finished
Posted: Fri Oct 21, 2016 8:58 pm
by Fermis
Started this a little bit ago...just cementing some parts together at the coffee table...small sub assemblies, ordnance, anything that didn't require paint or modification.
First bit of real work was with the pylons. Trumpeter, in all their greatness included Mavericks and Sidewinder missiles, but did NOT include the rails that those missiles require. I nabbed some extras from Academy's F-18 kit. (The Sidewinder rails are actually Sparrow rails, a bit modified...better than nothin!). Being that this build will be traveling across the country via the US Postal Service, extra measures are required. Brass pins were used to pin the rails to the pylons as well as the ordnance(coming later), there's also a pin the runs all the way through, from ordnance, through the rail, through the pylon and into the wing.
I went ahead and got these painted and weathered (as well as some other stuff not pictured) to save myself the trouble later. There's a lot of plane here!
Also got the landing gears done. I shaved off the molded on plumbing/wiring and replaced it with copper wire. The gear door that was molded as part of the gear was cut off...it was stupid thick and clunky. I scratched up a new one, as well as the actuator arms.
Painted up...
For the landing and taxi lights, I used a bit of aluminum foil, burnished in with a q-tip. Nice and shiny!
Next will be the cockpit!
Re: 1/32 Trumpy AV-8B wip
Posted: Fri Oct 21, 2016 9:05 pm
by Stikpusher
Very nice work so far! Looking at this and working on my 32nd F-4G I am starting to feel the allure of 32nd scale kits... OOB, they are adequate for the most part. But they really invite you to try your hand at adding detail of your own creation... This is gonna be good! :popcorn:
Posted: Sat Oct 22, 2016 9:26 am
by Paul
I think I have the det cord decals for the top of the canopy some where. If you want them I'll look round for you. Make sure that those pylons sit right on the wings or you will have some real gappy stores.
Posted: Sat Oct 22, 2016 10:08 am
by Fermis
Paul wrote:I think I have the det cord decals for the top of the canopy some where. If you want them I'll look round for you. Make sure that those pylons sit right on the wings or you will have some real gappy stores.
I appreciate that...but I just can't bring myself to put a decal on clear parts...never had a good reslut.
Pylons have been tested, trimmed, tested, trimmed...good fit!
Posted: Sun Oct 23, 2016 1:14 pm
by BlackSheep214
I agree on decals on clear parts. Nah... I'd probably opt for dry transfers instead with Future to seal it in or clear smoke for tinted look.
Posted: Mon Oct 24, 2016 7:29 am
by Fermis
Have moved on to the cockpit!
The seat is pretty basic, for 1/32...
The real thing...
I added some texture to the seat cushions, Tamiya tape for the harness and various do-dads elsewhere...
Added some plumbing/wiring to the rear bulkhead. The canopy frames detail is pretty sucky...I cut all of it off.
After removing the molded detail, I made it more better-er!
That took a LOT more time than it looks like it should...at least 10-12 hours.
The side walls won't need much, if even anything other than paint!
Posted: Mon Oct 24, 2016 7:38 am
by CallSignOWL
Whoop, that's looking good!
Posted: Mon Oct 24, 2016 11:05 am
by Stikpusher
:bow: Sweet work on the seat and canopy frame! Do you use tape to represent the wiring tie downs along the side of the canopy hood frame? (I'm getting ideas for use on my next new start 1/32 project) :writing:
Posted: Mon Oct 24, 2016 1:05 pm
by KSaarni
Ooh, this is great!
What else to expect... Fermis 1/72 are full of details... and now a 1/32 ... man, this is ggggreat!
Posted: Mon Oct 24, 2016 1:19 pm
by Cherrylock
:that:
Stikpusher wrote::bow: Sweet work on the seat and canopy frame! Do you use tape to represent the wiring tie downs along the side of the canopy hood frame? (I'm getting ideas for use on my next new start 1/32 project) :writing:
