Denmark cayuse - Italeri 1/72
Posted: Fri Jan 06, 2017 11:13 am
Heres my first new wip of the year : the little italeri cayuse that will be in denmark markings.. in some way i'll try as i don't have the decals
No sprues pictures (i think it's a notorius kit..) and i already started some work, as the rotor assembly and cockpit main pieces .
Going to rotor the kit have wrong spin direction, so i glued it upside down and replaced the control beams with stretched sprue
Glued missing pieces at cockpit
Le cloche assembly , removing ejector pins and copper wire to simulate IP cables
Spreading cables and cut'n'glue in place. Added details to the rotor head. the rotor cap is not needed.
Primer and after black (not pure black) painted
At the windscreen drilled two holes, closed after with plastic strip from inside
Drybrush
Complete IP
Cockpit too
almost done rotor
smashed lead as weight
After glued side windows with clear glossy vellejo used instead of glue , closed fuselage
Also the windscreen glued with clear glossy
Some rescribbing not yet finished
And more elements glued
At the next
Drybrush
Complete IP
Cockpit too
almost done rotor
At the next
