1/350 The USS Johnston at the Battle off Samar WIP
Posted: Sun Mar 19, 2017 9:31 pm
As some of you already know the USS Johnston DD-557 along with other DD's and DE's USS Hoel DD-533, USS Heermann DD-532, USS Samuel B. Roberts DE-413, USS Dennis DE-405, USS John C. Butler DE-339 and USS Raymond DE-341 attacked Vice Admiral Takeo Kurita's center force of 4 battleships in Yamato, Nagato, Kongo, Haruna and 6 heavy cruisers, 2 light cruisers and 11 destroyers on Oct 25 1944. They turned to lay a smoke screen, run torpedo attacks and generally harass the Japanese Center to protect the 6 escort carriers of Taffy 3, USS Fanshaw Bay CVE-70, USS St. Lo CVE-65, USS White Planes CVE-66, USS Kalinin Bay CVE-68, USS Gambier Bay CVE-73 and USS Kitun Bay CVE-71 which were off Leyte Gulf to support the landings on the Philippines.
Let me explain...no, not enough room...let me summarize,
the Johnston launched a torpedo spread at the cruiser Kumano. There is some speculation whether the Johnston or an Avenger from one of Taffy 3's air groups landed the blow forward of the number 10 frame which took off the Kumano's bow. The Johnston continued firing her 5" main guns and anything else she could bare even after she took several 14" or possibly 18" shells from one of the enemy Battleship rifles knocking out one of her boilers as she ducked into a squall. The Johnston reemerged out of the squall and continued the attack until she finally scummed to the multiple hits from the incoming fire of the cruisers and battleships.
I used the fantastic book "The Last Stand of the Tin Can Sailors" by James D. Hornfischer and episode 9 of the History Channel's Battle 360 for the inspiration of my diorama.
I started the build some time ago and have worked on it off and on. I has started installing the PE and am on the home stretch but will cover what I have done so far.
I am using Dragon's 1/350 The Sullavans for the Johnston since she was a square bridge Fletcher. I am also using Tom's Modelworks PE set and the 3D 1/350 Bofors crew from Shapeways.
The dio will be of the Johnston at flank speed turning to port getting ready to launch torpedoes to starboard.
Pictures to follow.
Thank you for your patience and for looking in.
Pictures to follow.
