Page 1 of 17
Revell 1/48 A-10
Posted: Sat Feb 02, 2019 10:44 am
by LyleW
I hesitate to start this thread. That is usually a jinx on finishing the kit (see the WIP thread on the KC-135A, and others....).
I have not taken any pictures as a deliberate attempt to thwart the little model meanies that lurk around my bench. I have so far gotten the fuselage closed up, the engine module closed and some bit of paint slapped on interior parts.
This kit has some of the worst instructions, fit, locating pins, etc. I've ever had the pleasure of trying to decipher.
I just want to get past the "oh man, this sucks" stage and get something finished. I do like that the landing gear can go on at the end....may not actually break these!!
Re: Revell 1/48 A-10
Posted: Sat Feb 02, 2019 10:56 am
by Stikpusher
That cockpit looks great! And don’t worry about too much smoothness. The A-10 was not built for speed.... she’s a brawler
Posted: Sat Feb 02, 2019 11:01 am
by LyleW
Stikpusher wrote:That cockpit looks great! And don’t worry about too much smoothness. The A-10 was not built for speed.... she’s a brawler
Thanks! Oh, it won't be smooth. Just trying to get the raised seams out. The parts seemed to close up ok, but there were ridges, like bits of flash. . . like the molds were not quite closed up enough. The IP was a decal and one side as well. the other one went poof....so a white Prismacolor pencil came out and highlighted some things.
Posted: Sat Feb 02, 2019 11:38 am
by Stikpusher
Well, those molds are from the late 80’s, so if you have a newer boxing of the kit...
Which scheme will you be doing this build in?
Posted: Sat Feb 02, 2019 12:45 pm
by Medicman71
Someone is building an A-10!!!!
Posted: Sat Feb 02, 2019 2:49 pm
by Handiabled
Alright Lyle! I am very glad you are at the bench again, A-10's are awesome! This looks great so far!
Posted: Sat Feb 02, 2019 5:18 pm
by Floki
Good luck on your build the Revell A10 is a real pig... Or should I say warthog
Posted: Sun Feb 03, 2019 12:09 pm
by BlackSheep214
Go, Lyle, Go!! You’ve got this! The cockpit is looking good there buddy!
Posted: Mon Feb 04, 2019 8:45 am
by LyleW
Stikpusher wrote:Well, those molds are from the late 80’s, so if you have a newer boxing of the kit...
Methinks the box top scheme. I have a lot of gray to use up.
Posted: Mon Feb 04, 2019 8:48 am
by LyleW
Medicman71 wrote:Someone is building an A-10!!!!
I am all giddy...or gassy. Let's hope for giddy. There is a series on the Smithsonian Channel on cable called
Air Warriors and the A-10 was featured. It made me want to dig this rascal out.
