I have lately read on a few modeling forums, that the Tamiya Airbrush cleaner ("the bottle with the pink cap") is (99%) same stuff as Tamiyas Extra Thin cement.
Inspired by the recent discussions regarding Mr Cement S, I thought, what a heck, let's make the same test as I did a few years back. I added in the test also AK's Quick Cement Extra Thin. (
Which is, at least based on the looks, a 100% copy of Tamiyas bottle, even the extendable brush attached to cap is identical. Only the color of the cap differs and perhaps the cement itself )
The approach was exactly the same as before, to glue two sprue pieces with a flattened end
So here are the test objects, curing for one hour, which should be enough.
One hour later..
Time to test how good the bond is...
Tamiya Airbrush cleaner... bends... bends... bends... and then SNAP, the bond gave up with quite loud sound.
But I'm impressed, as I was very sceptical to this fact. (apologies for the unsharp picture)
What about AK ?
Same process... bends, bends and slowly the bond gives up. Not as SNAP, but slowly breaks
CONCLUSION
Yes, one can use Tamiya Airbrush cleaner as cement, when needed. However, it smells horribly and seems it dries quite slowly. I made some other testings and noticed indeed that the cementing goes very slowly.
Will I throw away my TET bottles and go over to use the airbrush cleaner instead ? No I wont. Will I use ever the cleaner as cement ? Probably I might in situations where a very slow drying process is needed.
So, now we know it.
