1/48 Mono-cademy P-40 B "Pearl Harbor" (Work in Progress)..
Posted: Thu Sep 18, 2014 12:14 am
In my opinion the 1/48 P-40 B/C, the Tomahawk Model 81, is without a doubt the most under-represented subject in 1/48 scale, perhaps in any scale. How could such an important plane go so unrecognized? Let's see, the Monogram kit has been around since the Beatles invasion and the Hobbycraft (now Academy) version is rather "basic" and has glaring detail and inaccuracy issues. I built the Trumpeter kit recently and it was mediocre at best, with a crumby cockpit and mad rivets, more like potholes, everywhere. There's other stuff but they escape me at the moment. I simply cannot believe Eduard has not tackled this subject yet with their newfound kit technology. Like we need another Bf 109 (sorry, I like the Hasegawa versions).
Anyways, It is generally accepted that the Monogram P-40 is the most "accurate" in outline. The Hobbycraft has recessed panel lines and is easier to build. Armed with this logic, I decided to try to create reasonably accurate P-40 B by splicing the two. I intent to build one of the two P-40's that got airborne at Pearl Harbor and scored kills on the morning of December 7th 1941.
The most noticeable problem with the Academy kit is the belly, which is too flat and is more appropriate for later P-40 variants (Monogram in olive drab plastic).
To improve this area, I then endeavored to "graft" the Monogram belly onto the Academy kit. This would have been a piece of cake if I were to procure a Dremel tool, but I still I tend gravitate towards the hard way to do things....some day I'll learn. I first chopped off the belly of the Monogram kit with a #11 Exacto. It was easy because the Monogram plastic is soft and flimsy. I used the same blade and carved out a section of the Academy belly. I also thinned out the inside of the Monogram belly so it would be easier to manipulate into place.
Here you can see how it should look...huge difference
Some super glue, trimming and hefty sanding was in order, but I eventually got to this point. Some putty was needed as well.
A quick test fit revealed more sanding and forming was needed but we're getting there.....and more putty...
Once I thought it looked about right, I hit the area with primer to reveal any areas that needed more attention. I think this looks about right. Its not perfect but it will pass.
As I said before, the kit has other issues, such as a too narrow wing root fillets and inaccurate tail planes, but I can live with these. The belly modification should go a long way in improving things. I also hit up Sprue Brothers for a True Details cockpit and Eduard flaps which should further enhance the kit.
More to come soon.
Joe
More to come soon.
Joe
