Re: CB's Monogram 1/48 A-1H Skyraider Build
Posted: Tue Feb 07, 2023 8:15 pm
Forgive me for all the pictures -- I like photography as much as modeling...
Some filling is still needed around the upper cowl..
The bottom of the cowl did not line up when the top was lined up correctly plus it was a bit short shot on one side so I have to cover up with some styrene and do a bit of filling and sanding..
The air intake needs quite a bit of work as well -- I am thinking Apoxie Sculpt and lots of wiping with a wet cotton swab ...
The vert stab needed some work. The nav light on top was split in two , one half on each fuselage half, and of course, the two halves did not lign up, so lots of work with a file and sanding sticks made it look respectable I think.. I removed the actual light and just left the post so I will add the light later... The trim tab was molded as one piece as part of the right fuse half, resulting in a huge 'panel line' that needed to be filled and rescribed.
Forgot to install the prop shaft when I put the cowling on ...
I can never resist putting the propeller on for no particular reason...
