Fujimi 1/700 IJN Heavy Cruiser Chokai (Completed)
Re: Fujimi 1/700 IJN Heavy Cruiser Chokai
The improvement is astounding! Sure looks like it was worth it to use the PE so far. Beautiful.
- dmminiatures
- Master Member
I am a true Pe believer now, Lyle, especially for ship modeling. just give a lot of umph to the overall appearance
Moving rather quickly, the model was constructed without any complication. working on the PE as I understand now reduce my building speed to half.
This the painting process of the preshade color XF-63 German Grey and base color XF-24 Dark Grey.
this is the start of making a base color for the IJN Chokai's linoleum deck. I started off by applying XF-57 Buff
eventually the model looks like this. everything is done by careful airbrushing. no masking were used.
Monty / dmminiatures
OMG i see the wip pictures on Flickr Monty ! following with explanation of another masterpiece
- dmminiatures
- Master Member
Hi BsYamato - What's your Flickr name? Thanks from dropping by!
Anyway, sharing with the rest of the gang some of the updates pics from the WIP. The deck is linoleum and should be in a darker reddish brown color. I did not use any masking and everything is being done freehand using an airbrush. You can see the coloring of the deck to a more browner color.
You can see here that the deck is now a scale darker than the earlier spray. This is my first time doing a linoleum deck, so i am going extra careful not to overshoot the color too dark. To get a neat finish, I touched up the edges or any over-spray with a brush
- dmminiatures
- Master Member
The next stage of the Chokai is the installation of the main PE railing sets. These railings goes on the main and elevated deck.
You can see that I have glued some PEs BEFORE the model was painted, such as the railings on the superstructure; and some AFTER the model was painted. such as these. I used cyanoacrylate glue (aka superglue) as adhesive. I have heard that white glue works as well but I have never tried it.
- dmminiatures
- Master Member
Some of the super detailing that you can do with PE sets. in 1/700 scale, these pieces can drastically enhance the final look of the ship. this shows the ladder on the bow port side.
This image shows the catapults and crane. The level of detail outstrips the original plastic pieces.
I always like the color of unpainted PE
On flickr ia my real name, Silvio Petrolo
More good updates
More good updates
- dmminiatures
- Master Member
Fast forwarding the last parts of the build includes the detailing parts.
i used poster color as my washing materials. my regular mix is dab of Sakura poster color, mix with a dab of Sunlight dishwashing liquid, and add a few drops of water. trying to get a fluid consistency.
Working on the highlights. Here, adding enamel Tamiya XF-2 flat white on the main guns' canvas using a brush.
Drybrushing the structure using light shades of greys including Tamiya sky grey.
damn what a fiddley work, it looks great. I would end with tons of pe glued everywhere
- lawman56
- Advanced Member
Not me, it would all be glued to either my arms or fingers.....mlp wrote:damn what a fiddley work, it looks great. I would end with tons of pe glued everywhere
Joe
Illegitimi Non Carborundum
