X-35A, Revell, 1/48 FINISHED
Re: X-35A, Revell, 1/48
Floki wrote:So the X-35 didn't even have the doors for the weapon bay? That's some good information.
No, it did not. Nor did it have a radar in the nose either. It was truly an X-Plane design. Aside from the aerodynamics, which were quite close to those of the F-22 in the final design iteration, it was not testing out all of the systems that make the F-35 so advanced. That is where the program hit slowdowns was integrating all the high tech elements. I suspect that the engineers were over optimistic in their assessment of how long it would take the concepts to become reliably functioning reality.
Stuart wrote:That's really interesting about the bays Carlos.
I thought so too Stuart. Yet the X-32 demonstrator did have weapons bays. Again, my guess would be that since Lockheed already had the experience there with the F-22, they could skip that part for the 35.
Yesterday’s progress... I puttied the weapons bay seams, let it dry a few hours then sanded one side...
I’ll work on the other side today
Modelcrazy
Post by Modelcrazy »
Looking good Carlos. I like the additional detail in the pit.
Modelcrazy wrote:Looking good Carlos. I like the additional detail in the pit.
Thanks. I can’t wait to get it painted and glued in place
And much wet sanding later...
Great stuff Carlos!
Thumbs up, bud! You made the seams go bye-bye!
You made short work of all that sanding.
Those fills should disappear under a coat of paint! What kind of putty are you using there, Carlos?
Stuart wrote:Great stuff Carlos!
Thanks Stuart.
speedgraflex wrote:Thumbs up, bud! You made the seams go bye-bye!
Thanks Bruce. Bye bye they went!
Floki wrote:You made short work of all that sanding.
Yes, it did not take too long for all the sanding.
jkim wrote:Those fills should disappear under a coat of paint! What kind of putty are you using there, Carlos?
John that’s what I’m hoping will happen. When I prime in the cockpit, I’ll shoot the rest there to check for anything that I missed. I used Tamiya Gray Putty here. It’s really good stuff. I like it better than Squadron Green or White Putty.
