I see a rabbit hole in your future. You will try to resist. It will be futile.
Oh yes. The damn rabbit hole. I know it all to well.
She is insidious to be sure!
I don't worry about the rabbit hole - I back filled it with cement and put claymores around it
A super sounding project Carlos and a really cool idea to add that detailing - only a little will make all the difference!
Gonna put some shiny chrome parts in there too?
This is a tank Tom... no shiny chrome allowed...
So the last couple of days I've been working on the engine. Yesterday I cut off Italeri’s sorry excuse for the auxiliary motor and generator
Which looks nothing like the real thing
And I also sanded off all the incorrect detail molded on the oil coolers, and drilled in holes in preparation for plumbing lines.
Today I measured and cut lengths of styrene rod to make up the ignition harness for the cylinder banks, then glued them in place. I also created a section of the right side hull fuel tank that goes under the auxiliary motor
Then a test fit into the hull with the top on to show what will be visible
I still have a couple more sessions worth of work to add more details in there.
Huge improvement over the kit detail!
Thank you Clint. Give me a few more days in there. Then it’ll look proper. Curse you Joe!
That's coming along nicely Carlos!
