Seeing it all in white really helps to see all the detail you put into this.
Looks great!
That all looks like it was meant to be there - good work Carlos!
Clint, John, and Stuart, thank you. Yes, having it all in color removes the multi media look and now it’s starting to like like it does indeed all belong together.
I’ve got all the base colors on the power pack now. Just need a wash and then I can install it and get the hull assembly completed.
You did a great job adding all the extra bits. Now it just needs some dirt thrown in there.
Thanks Clint. Just a little bit of grime in there. This is gonna be in “motor pool” condition, so they are kept pretty clean there. And then a mechanic figure peeking in there to have a look see.
Very nice! You really made it look real!
Wash on and cleaned up, then power pack installed.
and what will be visible....
Time to get this one moving forward past this stage.
Man all that extra detail is really gonna POP when you get this thing all assembled. Looks fantastic Carlos!! :shoutout: :shoutout:
