AMT 1967 Chevrolet Impala SS
midnightprowler wrote:Beautiful.
Thank you!
Okay, this one is back....time to get this wench off the bench (see, it rhymes!) Anyway, I was remided by FB that it had been a year ago that this was active. . . so, here we are.
Looks like you're getting close to the finish line on this one too Lyle
it is...but that is where the wheels usually fall off the bus!
I like the blue. Let's see this one done. Never mind the wheels coming off the bus. You've got this, Lyle! :shoutout:
Not going too bad at this, but it was ohh so close...
You KNOW I'm gonna be on this one grasshoppa.
I know...
mustang1989 wrote:From the pictures I'm seeing this looks just fantastic Lyle. If you've got some dust bunnies or anything like that in the paint don't be afraid to wet sand it some. Start with 4000 and work your way towards the 12000 grit range if needed. I can't see anything here that needs addressed though. When you do polish go with the Novus 2 only. Save the Novus 1 till you're getting ready to put 'er on the shelf......or better yet....under glass.
BTW.....FANTASTIC work pal. You've done very well so far. :shoutout:
I agree with Mustang about the quality of your work, and the usage of high grit sandpaper. All too often the final stages of painting — the sanding and blending — are left out. Try the Novus series like he suggests.
Thanks! Yep, becoming a fan of the higher grit stuff.
