I'm adding 4 CMK resin sets, interiour, undercarrage, flaps and engines. I'll be useing kit markings for an aircraft from 75 (NZ) Sqn based at Feltwell in Norfolk.
The nose section inside had to be sanded smooth before fiting a coupl e of resin pieces.
The CMK set replaces most of the pit pieces but also adds a radion and navigators compartment which should be quite visible with that long window along the sides.
And the front and rear turrets with resin barrels and one small PE piece.
It got primed this evening and i'll get it painted in the morning. I'll be working on the engines and undercarrage tonight.
