P-40E Hasegawa 1/32
ajcmac
Senior Member
P-40E Hasegawa 1/32
Post by ajcmac »
This is another model that I have on the bench but is still awaiting the arrival of Eduard mask. It is a P-40 to E Texas Longhorn version.
The cockpit.
Air intakes to the radiator.
Fuselage and wings glued. Here a lot of putty and a lot of sandpaper.
Regards
ajcmac
ajcmac
Senior Member
Re: P-40E Hasegawa 1/32
Post by ajcmac »
I started painting the model with Azure Blue.
And then started the weathering.
I finished the propeller.
Regards
ajcmac
lawdog114
Post by lawdog114 »
Absolutely stunning! :yipee: Thanks for sharing........
Joe
Paul
Post by Paul »
I am a P-40 fan of the highest regard. Thia is going to be a good looking bird.
Great painting! I like the subtle streaks/grain I the paintwork, especially the prop.
Wow! Incredible paint work! Looks great!
ajcmac
Senior Member
Post by ajcmac »
Thank you all for the comments and for following :bow: .
I painted the wells of the landing gear.
Extra fuel tank ready.
Landing gear.
Regards
ajcmac
ajcmac
Senior Member
Post by ajcmac »
Must be the worst model of Hasegawa in 1/32 I've ever built. The old problem of the Hasegawa, with one mold, try to make different versions. The same applies to the model in 1/48 scale. I've also built one.
A fuselage that seems a lot of patchwork where they will fit the pieces for the different versions with a dubious fit.
Another piece, more putty, more sanding.
Here the windscreen with a 'frame' that does not exist. After sanding a bath with glossy varnish.
Regards
ajcmac
dmminiatures
Post by dmminiatures »
very nice work and detailing there. seing all these 1/32 builds makes me cringe: cant wait to go home and start my next 32nd one
Monty / dmminiatures
