Ceaser Tries Again
Something you have never built.
Re: Ceaser Tries Again
Stikpusher wrote:Declan, I don’t know how much you work with metal tubing and rod, but you can easily fix that broken stabilator using that stuff, make it work, and be even stronger. Nice seam clean up work, BTW.
That's exactly what I was thinking Carlos. Do both sides and adjust them as you like Declan! :grin:
Ceaser_Sa1ad
Post by Ceaser_Sa1ad »
Actually! I did that. I got some wire, twisted it up, drilled a hole in the stabilizer and then super glued it on. They work now. Thanks guys!
Ceaser_Sa1ad
Duke Maddog wrote:Speaking for myself, I have built a large quantity of Italeri planes, armor and helicopters, albeit in 1/72 scale. I don't recall having nearly as many issues as I'm seeing here. Maybe it's the scale, but I don't know. I've always loved Italeri kits.
Well I didn't really mind the seams. They were large, but really easy to deal with. I really want to do more of their kits. Good prices for good subjects in my opinion.
I'm not sure if it's too late to mention, but if you've not already glued the intakes, you should know that they should not be level with the top of the fuselage, but raised above it, as there is actually a vent at the top....
Ceaser_Sa1ad
:headslap: They fit so well being level with the fuse... Well, next time.
I like Italeri kits but every once in awhile there is one that just kicks my butt
Ceaser_Sa1ad
AHA! So I checked the molds, the intakes DO line up with the fuse molded intake bits. I just have to drill out the little vents, no problemo.
Ceaser_Sa1ad
Colour is on.
Still have to paint around the cockpit.
Ceaser_Sa1ad
Well a few days ago I did a 2nd layer of the desert colour. Now it is too thick, and the details are getting covered. :bored:
Sails are empty atm.
Return to “Cherry Popper Group Build”
