:bow: :bow: :bow: :bow:
Superb work John!
Thanks guys!
Here's a pic of that tail centering unit in case you thought I was just making things up!
:wow:
Great Work!
:wow:
I think you got that tail wheel assembly spot on John.
What colour are you using for you u/c bay primer? It looks a sort of greeny yellow?
Zinc Chromate yellow
Ah it's that is it - I have Zinc Chromate Green but not the yellow - I'll have to see what I can mix up.
Ummmm........I think we all know better than that John. With the amount of research that you put into your builds it's hard to think that you'd be making some of these details up. :giggles:
Stuart wrote: Tue Jan 17, 2023 4:24 am
tempestjohnny wrote: Tue Jan 17, 2023 4:16 am
Stuart, Testors 1/4 oz. line has a good yellow chromate enamel if that's available in your AO. :grin:
Humbrol Pale Yellow 81 is close to Yellow Zinc Chromate. Tamiya XF-4 Yellow Green is also a good substitute for the stuff.
Thanks Carlos - I should be able to get the Humbrol colour.
