Yeah it can be a pain in the arse. I generally just scribe in the missing detail - sounds mad I know, but once it's painted it's hard to tell.Medicman71 wrote: ↑Wed Feb 08, 2023 7:09 am Well I'll hold off but I hate raised panel lines cause they usually get destroyed when cleaning up the seams.
Monogram 1/48 TBD-1 Devastator
Re: Monogram 1/48 TBD-1 Devastator
Another option--You can always replace the sanded off lines with stretched sprue.
That sounds like WAY to much work.
Not if you heat the sprue first. Makes it much easier to stretch.
Got a few parts together. I added the center section to the bottom wing. This is for the torpedo. Also put a few parts of the cockpit together. I'm also working on the outer wings.
Yay! Off and running!
VT-8 launching into immortality at Midway
Good start Mike!Medicman71 wrote: ↑Fri Feb 24, 2023 6:31 pm Got a few parts together. I added the center section to the bottom wing. This is for the torpedo. Also put a few parts of the cockpit together. I'm also working on the outer wings.
