Garage looks great
I'm so glad that I have enough room in the house for bench and display in our home office. Here its not so much the heat its the humidity.
But the previous owner of my house did put a mini split in the garage
Stik's Workshop
- Gary Brantley
Re: Stik's Workshop
That's a good work space Carlos! Having the a/c gives you a true year-round place to work; great plan there!
Re: Stik's Workshop
John, the garage will get hot in the summer. Those vents to let out exhaust fumes from the cars let in the hot air. The insulation may tamp it down a bit, but without some AC in there it will easily get over 100* in there.
TJ, I hear ya about having the bench indoors. But since I still do use lots of enamels and lacquer thinners, I prefer to keep those fumes out in the garage. Not to mention the noise from my dual use compressor. Humidity is rarely an issue around here aside from during the summer monsoon.
Thanks Gary. One other nice feature that I found with the AC is that it also can warm up the garage, which came in handy during the cold snap that we had here this past winter. So yes, truly comfy and optimal work temps in there year round. Some folks don't realize how cold the desert can get at night or early morning in the winter months.
Re: Stik's Workshop
Yes but you guys have a dry heat. Here it's hot as balls and then we add 100% humidity.
- Gary Brantley
Re: Stik's Workshop
Keeps out the riff-raff.
Re: Stik's Workshop
Unfortunately I don't think it's working.
Re: Stik's Workshop
I remember the first time I flew in to Houston. I went there to look at an air compressor ( 1300cfm type for well drilling). I thought it was a fog type undercast from about 3000 feet to the ground, but no, it was just so humid you could only see about 2 miles once you got down into it. The fellow who picked me up at the airport had a broken air conditioner, and there was so much rust and corrosion on the compressor I went to look at that I could practically see through it. A quick ride back to the airport and I cranked up the Travel Air and got out of there. I guess us California types are just wimps. I spent quite a bit of time in Abilene and the Ft. Worth/Dallas area but Houston is a thing of its own weatherwise.
- Gary Brantley
Re: Stik's Workshop
No, sadly, you're so right.
I once read a quote, said "If Texas was tilted on its side, everything that wasn't tied down would go to Houston". When I was in high school, '76-'71, Houston was the place to go for high-paying jobs after graduation. The downside was you had to move there.
Re: Stik's Workshop
After spending time on the east side of the Red River at Ft Polk, Houston was not bad at all… lol! And California west of the desert felt almost cold in July/August by comparison… and compared to the Mohave desert in summer, well it was the proverbial dry heat as opposed to the swamps & bayous
- Gary Brantley
Re: Stik's Workshop
"Tigerland"?
My cousin Thomas had a lot to say about basic training there...
