Academy 1/48 Spitfire Mk.XIVe
Ceaser_Sa1ad
Re: Academy 1/48 Spitfire Mk.XIVe
Post by Ceaser_Sa1ad »
Looks like a great start!
Thanks guys! It’s coming along well so far.
cbaltrin wrote: Mon Aug 07, 2023 5:02 am I think I built the monigram spitfire as a kid and my current AFX mk V is stalled after I dropped it and broke off a 20mm barrel... :bag:
Chris, I built one or two of those long ago as well. Come to think of it, those were probably the only 1/48 Spitfires that I ever built until my first 1/48 Academy Spitfire came along.
You ought to be able to find a replacement 20mm barrel from some AM company… or even scratch build one easily using styrene rod sanded to shape…
Nice work on the XIVe! I like the interior green color.
Thanks John. I used Tamiya's Cockpit Green XF-71. Even though it is a color for Japanese aircraft, it is very close to RAF interior green, and to my eye is an acceptable substitute.
Stikpusher wrote: Wed Aug 09, 2023 10:06 am Thanks guys! It’s coming along well so far.
Right, I have work up to it though since most of the painting was already done when I dropped it :headslap:
Ouch! I’ve lost plenty of parts, but usually before painting… :headslap:
Stikpusher wrote: Fri Aug 11, 2023 9:26 pm Ouch! I’ve lost plenty of parts, but usually before painting… :headslap:
:P1:
Now that I have several other projects wrapped up, this one is back as my focus point.
I have finished up painting of the interior parts and salvaged a late war RAF PE seat harness off an older scrapped build.
next up, get this all installed and get the fuselage closed up...
Looking good Stik. Didn't realize until just now she's a recon bird. Even more interesting :hmm:
Cockpit looks great, Carlos!
Does your kit come with a small part on fuselage bottom underneath the rear edge of the canopy? It looks like a semi-circle in profile with a little pipe sticking out pointing rearward. Doing some research on my XIVe conversion, I noticed it on the plane that I am planning to model...
Just trying to figure out what it is and what it looks like so I can add it to my build.
