Hobby Boss 1/48 F8F-2 Bearcat COMPLETE
Re: Hobby Boss 1/48 F8F-2 Bearcat COMPLETE
Awesome build!!! :shoutout: :shoutout: :shoutout:
That is a very nice Bearcat indeed! :shoutout: :shoutout: :shoutout: :shoutout: :shoutout:
Couldn't you put the Tigercat on a base and pin the wheels?
Thanks all.
I could do. I have a PSP base but it's a bit large. We'll see. I have a couple of tail sitters that I've fashioned a tail stand out of clear sprue. When they are up on the shelf you really don't notice.
Oh, man, the Blackhawk Squadron will be all over you, John!
Do we need an F7F GB? I read a review that it takes 60 grams nose weight.
I'll take my chances with the Blackhawks :ballbat:
Already got started on the F7F
Very cool John!
John, one of the problems I faced with my AMT Tigercat was attaching the main landing gear. if I recall, there are multiple attachment points, and the instructions would have you "fish" the gear assembly up into the nacelle. The gear assembly is kinda spindly and fragile and I could see trouble getting it into place. Instead, I installed them into the finished nacelle from the top and then mounted the nacelle to its respective wing half. I had to mask around the protruding landing gear (even placed a section of paper towel tube around each for protection) but that seemed easier than doing per instructions. I look forward to seeing your Tigercat build! :grin:
Thanks for the tip Gary. I have have the metal gear which may help, but I'll look into dry fitting etc.
keavdog wrote: Fri Jun 21, 2024 8:00 am Thanks for the tip Gary. I have have the metal gear which may help, but I'll look into dry fitting etc.
You're welcome! I bought a set of metal LG for my Tigercat; in the end, I used some of the kit parts combined with the metal. Look into weighted plumbers' putty and pack the nose with that. :wink: Had I remembered that step, along with all the other weight I added, I believe my model would've sat on all three. As I had to resort to using the barrel and crate to prop up the rear anyway, I might as well just have used the kit parts and no ballast at all! :grin:
That’s where I’m at. Not even trying any weight. Barrel or a clear tail stand.
