At that price?
Tamiya Flat Base?
- Proud Marine Dad
- Gary Brantley
Re: Tamiya Flat Base?
Nope, I found some closer to home!
- Proud Marine Dad
- Proud Marine Dad
Thanks for the heads up.BlackSheep214 wrote: ↑Mon Jul 15, 2024 12:21 pmJust don't get their gloss black base coat. There's been horror stories about them.
Nowadays I prefer to use lacquer thinner with the Humbrol Flat Coat. Before that Testors Universal Enamel Thinner was my go to, but since that has been discontinued…Gary Brantley wrote: ↑Mon Jul 15, 2024 11:19 am Carlos, please indulge me for one more question; what thinner (if needed?) do you use with this Humbrol clear?![]()
Play with your ratios on a test mule subject for best results.
- Gary Brantley
Copy that! Thanks!Stikpusher wrote: ↑Mon Jul 15, 2024 7:14 pmNowadays I prefer to use lacquer thinner with the Humbrol Flat Coat. Before that Testors Universal Enamel Thinner was my go to, but since that has been discontinued…Gary Brantley wrote: ↑Mon Jul 15, 2024 11:19 am Carlos, please indulge me for one more question; what thinner (if needed?) do you use with this Humbrol clear?![]()
- Gary Brantley
Carlos, I've been doing some 'net research and find numerous complaints about the Humbrol matte varnish; it seems many felt it turned chalky white on their model. Have you ever experienced that? I will sure test it on my paint mule first, but I want to prevent any issues before they happen, I guess.
I suppose if it’s not thinned at all or barely thinned it could do that. But no, I haven’t had any of my models turn chalky white from the stuff. If you put on a heavy coat it will give a typical overdone Matt coat look, but nothing out of line. All I can say is to thin it down. A little goes a long way. And unlike many other flat coats I’ve used, this stuff won’t give that satin look. I’ve had that from Tamiya & Gunze in the past.
- Gary Brantley
Good to hear that, Carlos!
The Hobbycraft 109-7 was the last model I clear-coated with good ol' Model Master acrylic flat and it looked very "satiny". I found out that the needle on my Gaahleri AB was too small and spraying the clear flat through it made it look that way.
I switched over to the old Paasche H and tried it again; voila, there was the flat look I wanted. Maybe not as matte as I wanted though for a bird based in the North African desert.
Carlos, before I sprayed Future for a glosscoat, this was the effect I had:
After the gloss was sprayed, so much of the faded look was obscured. I was disappointed and hoped that a good matte coat would bring it back. It did help, but it still looks shinier than I want. I'm hoping to try that Humbrol over it next, but I will definitely try it on the paint mule first.
Here, you can see what I mean; not as much contrast left between those carefully "faded" colors:
My usual go-to clears, both flat and gloss is Testors in the big bottles - both enamel based. I also have flat and semi-gloss acrylic clears in Pollyscale. (or is it Aeromaster? I can't recall
