A couple of Cold War Warriors.
Re: A couple of Cold War Warriors.
Looking good, Stuart.
Paintwork so far outstanding !Stuart wrote: ↑Tue Apr 01, 2025 11:55 am So putting the Chieftain asides for a while, I've been concentrating on getting the basic colours down on the M48A3.
The OD is on, and I've started to drybrush the upper hull with a light green just to break it up a bit - all prior to decals and weathering. I've also painted the wheels and tracks and base colours and need to work on them also.
Detail painting next.
Cheers!
Thanks Gents - much appreciated!
You know, I'm really regretting closing the commander's hatch - I think it would have looked a lot better open with the figure. Might just have to live with it - I have, however, just bought some C ration boxes for the stowage.
Bum.... I thought as much. Not a big deal to remove the barrel and drill out the mount though. Thanks Carlos.Stikpusher wrote: ↑Tue Apr 01, 2025 1:12 pmCorrect. If the .50 is mounted externally, it is removed from the cupola interior.
You ca n try applying Tamiya Extra Thon, and try to pop it loose, or the Tamiya Airbrush Cleaner should work, too.
- Gary Brantley
That's a great tip, Lyle!
Necessity is the mother of invention.
Yeah I bet! We've all been there before.
A great tip Lyle, I'll try that. I think it would be good to have a figure in the hatch - especially as I might, just might, put it on a base.
And work progresses on the Tamiya M48. I''ve just sprayed a gloss coat ready for decals. Tracks are in paint and I'm just painting the tyres on the roadwheels. I've had a looksee at opening the hatch, but then decided not to bother.
Looks really good Stuart!
Interesting to follow, in what order the kit is made. I almost paint the roadwheels etc first, before hitting the rest. Only reason being, to get rid of the most boring part (in my opinion)
Hi All,
WOW! I'm a bit behind with the old updates on this one - well decals are on, wheels and tracks painted etc. I'm just in the process of cleaning of the Flory's 'Grime' wash I put on it and then I'll hit it with some
Vietnam mud
, because as we all know - all the mud in Vietnam is red.
