Tamiya 1/48 P-51D Mustang
Re: Tamiya 1/48 P-51D Mustang
Nope nothing installed correctly that im aware of. I did test fit first and again before applying glue. Once I glued it in place, top wings wouldn't fit. Don't know if top wings were warped or the framework were a tad too high. Who knows.
I do know top wings did fit perfectly to bottom prior to framework of wheel well assembly. Maybe I missed something I overlooked. I don't know.
Would I get another Eduard kit again. Yes. I want to give it another go at it. Maybe I'll discover what I may have overlooked, missed and why it didnt fit the first time around.
I do have the Eduard Butcher bird in my stash though.
I think it’s the design, Tom. Similar to ZM and even old Trimaster kits, the more the designers include inside the cockpit the finer the tolerances of fit become. I saw how much you ground down; that definitely leads me to believe that what was stuffed inside the fuselage affects the overall fit and dry fitting would not catch that per se.
Quite possible.
Fiddly bits removed. No breaks.
Time for a bit of surgery is next
Surgery is a success after careful sanding and grinding in variable speeds with both dremel tools. Place a small plate of styrene sheet on bottom for support to hold parts.
Coming along, Tom. Following you!
I'll throw some paint on before attaching recycled parts. I am curious to compare the seats from the Eduard and Tamiya. Same with the joystick.
Looking forward to the next stage!
Found a few more parts from the Eduard kit I’ll repurpose into this kit. The cockpit is painted, now I need to throw a coat of black detail wash before finishing up the assembly. Stay tuned…
Looking forward, Tom.
