The detail is lovely - but what I don't get with this kit is why they included the PE at all. Asides from the seat-belts every PE part could have, just as easily, been moulded in plastic with the same level of detail and less hassle in construction. It's a very odd design choice. Mind you, it's not the worst bit, the absolute worst bit is the total bastard of an armoured windscreen as a separate part - Just why? It's next to impossible to fit without glue running up between the two parts, or you don't use enough and it fall off. I've already had polish both bits with Micromesh to remove glue fogging once , and I've tried three different glues so far.
Personally, I'd have like to have seen separate windshield with the armoured glass moulded in. They could have covered the cost by removing the pointless PE Fret.
