I have used Eduards PE instrument panel, which looks really good.
especially compared to the plastic version
There were some steps carried out, before attaching all the pieces into the left fuselage half. However, those steps were never documented (some hassle with the PE belts for example, not ideal...), but below is the final result before wrapping up the fuselage halves.
Though, before the fuselage halves can be mated, I need to work with the Mercedes engine, would be too difficult afterwards squeeze it in.
As a matter of fact, I have worked on an Eduard 1:48 Fokker D.VII before, it was in summer 2014.
Wouh, that is 12 years ago but luckily most of the pieces (if not all) and left-over sprues were nicely kept in an old shoe box. So I picked the Mercedes engine from there and rather quickly assembled it, adding some details.
Though, the details will not really be visible, so no worries about the added brass rod that is not really straight..
Not sure if I will re-do the engine or not. Will see
